Rs4 b9 issue
2.9 V6 24v TFSI - 444 bhp
Smara
Rs4 b9 issue
Post by Smara » Sat Jun 30, 2018 10:37 am
Hi,
I have an Rs4 b9 with 1500 miles. Yesterday for the second time I experienced the following:
When travelling in the motorway in high gear between 2000 and 3000 rpm constant speed (with or without the speed limiter) the car every 20-30 seconds loses speed for a couple of seconds). It is barely noticeable but you can feel it. As a proof when setting the speed limiter, say at 80 mil/hr and watching the instant fuel consumpion indicator, you can see that when that happpens the ecu compensates the decrease in power with some more power. That happened twice after many min les after start. I still haven’t checked with Audi dealer.
Does anybody has had similar experience?
Thank you very much for you answer,
Andrew
Terminator_X
Re: Rs4 b9 issue
Post by Terminator_X » Sat Jun 30, 2018 12:10 pm
Nope not on mine now 5k in.
TX.
KiwiRS4driver
Re: Rs4 b9 issue
Post by KiwiRS4driver » Sat Jun 30, 2018 1:29 pm
I’ve not had this either, and I’ve done quite a bit of driving up and down a new stretch of motorway at around 120km/h both with and without cruise control. It’s smooth as a baby’s bum so I’d definitely notice if there were little blips like you’re experiencing. You say it happens with our without cruise control on, so it’s not the adaptive cruise kicking in then (I recently discovered the adaptive cruise won’t let you go past traffic if you are on the outside (slow) lane and some moron is sitting in the fast lane). Back to the dealer I say. Sounds like an electronic gremlin of some kind.
_____________________________________________
2018 B9 RS4
2016 Range Rover Sport 3.0 HSE
2015 B8 RS4 (gone)
2014 Mini Cooper S (gone)
2012 Mini Cooper S (gone)
Smara
Re: Rs4 b9 issue
Post by Smara » Sat Jun 30, 2018 3:47 pm
Will do hoping in a easy solution. I’ve read in some forums problems with the torque converter, but signs seem to be slightly different. Will keep you posted
Markp
Re: Rs4 b9 issue
Post by Markp » Sun Jul 01, 2018 7:33 am
Is it the fuel saving coast function?
Smara
Re: Rs4 b9 issue
Post by Smara » Sun Jul 01, 2018 8:21 am
It doesn’t sound like, as this function operates when removing power (decelerating) and not at constant throttle.
Markp
Re: Rs4 b9 issue
Post by Markp » Sun Jul 01, 2018 10:30 am
Coast works on lifting throttle (decelerating). Gearbox indicator changes too.
Smara
Re: Rs4 b9 issue
Post by Smara » Sun Jul 01, 2018 7:09 pm
Isn’t coast the disengagement of the gearbox to save fuel ? Sorry maybe I got it wrong
Re: Rs4 b9 issue
Post by MikeFish » Sun Jul 01, 2018 7:16 pm
Does this engine have the cylinder on demand function?
Graeme4130
Re: Rs4 b9 issue
Post by Graeme4130 » Sun Jul 01, 2018 7:19 pm
I don't get that on mine, and its 3.5k miles in
Saying that, it's pretty rare I sit at 80mph ;)
Smara
Re: Rs4 b9 issue
Post by Smara » Sun Jul 01, 2018 7:26 pm
8) 8)
Smara
Re: Rs4 b9 issue
Post by Smara » Sun Jul 01, 2018 7:27 pm
I don’t think so
PieterZ
Re: Rs4 b9 issue
Post by PieterZ » Sun Jul 01, 2018 8:23 pm
Strange. What do you mean by losing speed?
Do you keep the throttle in the same position and it then drops in speed?
If so I never noticed this in mine if that helps. I have almost 5k km now.
All black B9 RS4
Smara
Re: Rs4 b9 issue
Post by Smara » Sun Jul 01, 2018 8:24 pm
As if it was a misfire for one or two seconds, barely noticeable but you can feel it.
Markp
Re: Rs4 b9 issue
Post by Markp » Mon Jul 02, 2018 7:33 pm
Yes - as you lift (decelerate) you sometimes get a momentary “cough” as it cuts in or out.
No COD on the 4 but occasional hesitation common on 6 when COD cuts in and out.
Users browsing this forum: k-wise and 22 guests
