Car won’t boost more than 5 psi, boost leak?
Scanned with Vag Com, no codes but the car won’t boost past 5 psi. Requested boost versus actual boost is way off.
Do I have a boost leak somewhere? I’ve already checked intercooler hoses and swapped the n75 out with a spare.
Car is 034 chipped and I have Wagner ic’s.
03 RS6 sedan V8TT, 03 S6 Avant V8, 06 Touareg V8, 03 Silverado V8
All V8’s in my garage because America
Re: Car won’t boost more than 5 psi, boost leak?
What are your MAFs reading?
And your trim values?
Pull your DVs off and test them (suck test).
Had already swapped dv’s. Forgot to mention that.Shoppinit wrote:What are your MAFs reading?
I’ll try to get those other readings tonight.
Recently i just check my Intercooler and noticed the oil at the edge on both of my intercooler,
and i pressure test them, they are absolutely leaking~~
since this is very easy to check, you can check this area too when you got time.
I'm not familiar with this method - would you mind explaining in great detail?
2004 Audi RS6 Avant Plus #283
Well... when you suck your DV off it's a blowjob. When you pull your DV off, it's the wank test.
Ah, sounds like one could really enjoy this. I'll have to give it a go.
You make any progress on this?
Sorry, but no. Suspension issues were a bit more pressing due to bad drc and upper control arms. Got in to that last night, and needless to say I will never buy a car that isn’t from the west coast again. Frozen pinch bolts on both sides.Shoppinit wrote:You make any progress on this?
Wish they all could be Californian, eh?
Shoppinit wrote:Wish they all could be Californian, eh?
I live near Seattle so I’m not used to dealing with corrosion at all
Success.
Nicknamed the bastard bolt for a good reason.
Users browsing this forum: Google Adsense [Bot] and 116 guests
