Battery charging for simpleton
Audi Pardner
Post by Audi Pardner » Sun May 13, 2018 7:13 pm
Hi all
Haven’t used the car for 2+ weeks. Got back off holiday and neighbour said they’d heard the alarm (Viper) going off in the garage but they saw no sign of attempted break in. After a few hours the alarm got weaker then went off.
Battery’s obviously flat so unlocked driver’s door with the key. I’d also left the bloody dashcam on which hadn’t helped :drink:
Can’t open the tailgate to get to the battery so need to charge it from under the bonnet. The +ve terminal is obviously under the red plastic cap. Is the -ve terminal the metal tube to the right about 6” long?
Ta
mikep99
Re: Battery charging for simpleton
Post by mikep99 » Sun May 13, 2018 7:26 pm
Hi,
Yep, thats correct. Just use that tube for -ve.
I've had no problems in the past doing it this way.
ta
Mike
Audi Pardner
Post by Audi Pardner » Sun May 13, 2018 7:48 pm
Hi,
ta
Mike
Thanks bud. I’ve lost the owner’s manual so wanted to make sure before I cause an electrical fire :wink:
Post by MikeFish » Sun May 13, 2018 7:49 pm
Yep Mike is right.
Audi Pardner
Post by Audi Pardner » Sun May 13, 2018 9:00 pm
Yep Mike is right.
:beerchug:
mikep99
Post by mikep99 » Sun May 13, 2018 9:07 pm
you might also have to resync your key and the one shot windows once charged...
nothing too taxing...
Mike
Audi Pardner
Post by Audi Pardner » Wed May 16, 2018 7:14 pm
What’s the one shot windows Mike; is it the closing function with the key?
mikep99
Post by mikep99 » Wed May 16, 2018 7:19 pm
its the function on the switches inside that drop the window with one touch rather than having to hold the switch down.
the closing function with the key should work as you have to hold the button down all the time anyway.
Mike
Audi Pardner
Post by Audi Pardner » Thu May 17, 2018 10:04 pm
Ah, I’m with you now. Thanks.
Tried charging the car tonight but the alarm (Viper) kept pipping loudly all the time (like the ‘warn-away’ function when someone looks through the window), so I’ll have to talk to Antony at Securemycar.com for advice.
RS4eddie
Post by RS4eddie » Fri May 18, 2018 2:41 am
Might want to think about getting a battery tender when not using the car for extended periods of time. I don't daily mine so it's always on the tender.
2007 RS4 | Phantom Black | Milltek'ed | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | K&N Filtered | Ziza lit | Lamix-ed | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
Audi Pardner
Post by Audi Pardner » Fri May 18, 2018 6:41 am
Might want to think about getting a battery tender when not using the car for extended periods of time. I don't daily mine so it's always on the tender. Image
Yeah, I’ve got a Ctek which I use all the time, but I didn’t have it connected when I went away. Oh well, lesson learned..... :bash:
Users browsing this forum: Google Adsense [Bot] and 333 guests
