Air con boys.
Lukes3
Air con boys.
Post by Lukes3 » Sat May 05, 2018 4:23 pm
Any idea why my air con is not cold? Just had it re-gased no faults an i have turned air con on but is just gets luke warm?
Jon_J
Re: Air con boys.
Post by Jon_J » Sat May 05, 2018 4:38 pm
Take it back to where you had it done.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
Davidol
Re: Air con boys.
Post by Davidol » Sun May 06, 2018 9:17 pm
Mine was the pump that had failed, it’s driven via a shaft that runs through the block and from memory the engine has to be lowered slightly to get it out, my mechanic said it was fun :biggrin3:
£1600 roughly from memory
Lukes3
Re: Air con boys.
Post by Lukes3 » Sun May 06, 2018 10:18 pm
Cheers lads, i think its going to be the pump, but ill get it checked out,
When i had the front end off a while ago it looked ok ish to get to,
James1984
Re: Air con boys.
Post by James1984 » Mon May 07, 2018 12:06 am
Does the clutch in the pully engage do you know?
Re: Air con boys.
Post by chunky79 » Mon May 07, 2018 6:33 am
Who did the re-gas? You can tell if the system is working correctly by the gauges on the air con system.
Why did you have it re-gassed, cause it wasn't working at all or cause it wasn't as cold as it used to be?
Lukes3
Re: Air con boys.
Post by Lukes3 » Mon May 07, 2018 8:21 am
Not sure if it is there is no drop in rpm when switched on and the air con fan dose not drop in,
But i have tested the fan with VCDS an all is well
Lukes3
Re: Air con boys.
Post by Lukes3 » Mon May 07, 2018 8:24 am
Midland vw done the regas. I had the re-gas done because of having the front end off when fitting the the supercharger but saying that it has never been cold cold since having the car thinking about it.
Re: Air con boys.
Post by chunky79 » Mon May 07, 2018 9:22 am
You could either have a leak which they should have informed you of when re-gassing, or you have a blockage in the system, which they also could/should have informed you about.
Users browsing this forum: Google Adsense [Bot] and 90 guests
