Wheel Spacers for S4
I am trying to clear a set of Movit brake calipers without rubbing the tyre on the wheel arch - so I am looking for 5mm (or less) wheel spacer with the correct tapered lip that fits the standard 17" wheel and hub - not a MTM version with a lip.
Anyone with any thoughts on how I can achieve this???
RE: Wheel Spacers for S4
You may be able to source hubcentric spacers from AMD or OCT tuning, depending on where you are.
Rgds
Simon
K04's, Tanoga, full Milltek, H&R, S4 B6 alloys, RS4 calipers and drilled discs, AWE DTS,
Rgds
Simon
- gavsteryoung
I got some 5mm spacers from a guy on here called Philwalker, you could try PM'ing him. They are made by Eibach.
Previosuly I had some cheapo 3mm spacers but there was not much metal involved..... 3mm looks best 5mm makes the wheels stickout a little to far. Believe it or not the extra 2mm can be seen.....
09 Audi S3 - Sprint Blue
99 Audi S4 - Ming Blue - (Gone but not forgotten)
04 Vauxhall Tigra 1.8 Sport - Antiga Blue (The Mrs Car)
Yes, try Philipwalker on here - he sorted me out for these
Clive
Thanks guys,
Did yopu have any problems with rubbing with 5mm spacers - it looks very tight under them arches!
Not problems at all, but I have the B6 18" wheels and stock calipers
Clive
- tdiquattro
Have a look at this, I had a problem with the B6 18" S4 alloys not cetering at the front on 5mm eibach spacers, (the rears were fine with 5mm) The hub is not long enough to engage the wheel and you can see it isnt centred when you have tightened the bolts, so...... Add 4 blobs of weld, machine down the spacer to 3mm and a taper to exactly fit the wheel !!...........
[img]modules/pnCPG/Coppermine/albums/userpics/10567/rs246_norm_Copy%20of%20IMG_0438.JPG[/img]
[img]modules/pnCPG/Coppermine/albums/userpics/10567/rs246_norm_Copy%20of%20IMG_0441.JPG[/img]
[img]modules/pnCPG/Coppermine/albums/userpics/10567/rs246_norm_Copy%20of%20IMG_0439.JPG[/img]
Nige'
2000 silver S4 Saloon
- 5th Gear
Users browsing this forum: No registered users and 69 guests
