Spacers... where to source? Fitting?
Hey all....
Right, spacers - what’s everyone running? And where did you source them from? Never really done spacers before, I presume they are simple to fit? Just take the wheel off put them on the hub and then re-do the wheel up?
Appreciate your insights
Audi RS6 C7 2015 - Sepang Blue
Previous; 997.2 GTS, 997.2 C2s, 997.1 C2s, Jag XFR-S
Re: Spacers... where to source? Fitting?
Yeah pretty much. I normally put a bit of copper grease on them to make them easier to remove later but not too much otherwise it flies everywhere and then burns and stinks when it gets hot.
Buy them from Virdee on here.
I’m thinking the same, what size are you thinking of going for?
Will you lower the car as well?
Don’t really know what size to go, was hoping to get some guidance and photos of people who have added them so I can gauge roughly how far to go so to speak
Virdee? Is that a member or a Shop bud?
Do a search, been discussed a load of times already with photos. Depends which wheels / tyres you have and how low you are.
Search for spacers and sure he will come up.
Got my H&R spacers with longer bolts and locking nut form Glenn at Revolution247.com
as above easy to fit wheel off hub on wheel back on and re check the torque after a 20 min drive
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Thanks guys.. appreciate all of the insight and comments...
Mike I’m running 21 inch wheels ansnstandard suspension set up
- Surrey Sam
Remind me what you're running on your B8 again Brooner, 8mm or 10's?
10mm front and rear been on for couple of years now with no issuesSurrey Sam wrote: ↑Sun Apr 15, 2018 12:13 pmRemind me what you're running on your B8 again Brooner, 8mm or 10's?
Then it depends on how much you want the wheels to stick out and how many stone chips you want to collect. Have you looked at the photos on the other 2 threads for examples of different widths?
Yeah I’ve just looked at them now...
Stone chips? Huh?
I just want the wheels to sit a bit more flush, giving it a slightly wider stance...
Are you saying I’ll have to lower it as well as space it?
Stone chips? Huh?
Users browsing this forum: Google Adsense [Bot] and 34 guests
