Sportec RS600
Re: Sportec RS600
Noice, real fucken noice. Have you treated 5th and 6th pinions to anything?
Re: Sportec RS600
Thanks. No cryo treating or anything. We will see how it holds up I guess, lolbam_bam wrote:Noice, real fucken noice. Have you treated 5th and 6th pinions to anything?
Re: Sportec RS600
I'm very interested in the gearbox, especially:
- billet main shaft - my car has been through a lot of input shafts etc.
- wavetrac diff, gripper or Quaife - because fucken RACECAR!
- 4:1 center diff mod - trying to dial out the under-steer in these cars is the holy-grail innit.
Other than that, what torque are you excepting and what clutch are you going for?
Best of luck, keep it going.
Re: Sportec RS600
Well if I part it out I'll let you know haha!bam_bam wrote:I'm very interested in the gearbox, especially:
I really have no idea on power level. I'll let you know though!
It's on a clutch master cm850 twin disk with their internal slave cylinder.
Did you have any pics of you build you could link me to? Would be interested to see how the manifolds look and the inlets and airbox
Re: Sportec RS600
There is no build thread. Just a couple of videos, you can see the intakes in this one.
I am going to have it pulled apart soon and redesign the air delivery and clean up the front sub-frame. I like the idea of an air ramp against the bonnet and vented only to reduce pressure behind the rad, pull more cooling for rad and FMCC. It'll most likely end up with a double mushroom style air filter. There are no MAFs just manual wastegate.
Gearbox needs to be rebuilt with the carbon coated syncro rings, 3rd gear is almost useless but 5th and 6th are treated.
I'd also like to try another clutch, looking at a 3 plate kevlar or 2 plater with a modified B7 PP - both good for 1500Nm and 1100Nm respectively but another flywheel might need to be made. It's currently running a Spec stage 3+ but it's right on the limit straight from the off anyways, very drivable though.
Re: Sportec RS600
Awesome! Are those numbers at the wheels or crank?bam_bam wrote:There is no build thread. Just a couple of videos, you can see the intakes in this one.
I'm not keen on cutting the hood up. I'd like it to look as stock as possible but that's just me. I guess if it was a HUGE gain increase id be for it.
That sucks about your gearbox. Hope you get it sorted. JHM makes a carbon synchro kit for like $600 USD and included an updated 1-2 shift collar.
As far as clutch goes it depends on your setup. If you have an adapter plate for the trans then your flywheel will be different than mine. I have w twin disk in my b5 same as the rs6 and it's just ok. It holds all the power and whatever I wanna do to it (drop it or slip it) but it's not very fun to drive around town lol.
Re: Sportec RS600
Crank power.
Torque is limited in 1st and 2nd. It's the 3rd gear synchro that's borked, it's probably running the old brass jobbies. There are loads of kits available, even in London! It's just finding someone that can do it properly that's difficult. I'd also like to strengthen other bits in the box too, need to do more research and get a list of priorities.
The kevlar versions of the clutches I'm looking at should 'feel' OE but I'd doubt they'd last very long in slip mode. It wouldn't be so bad if the turbos weren't wrapped around the gearbox, meaning that every time that I want to change a clutch the whole lot has gotta come out. So, ideally I'd like to get it right, however, even if I do get it right, these new clutches will hold ALL the torque, so no doubt it'll just start breaking other bits on the drivetrain.
Square one.
Square one.
Re: Sportec RS600
great numbers. Was this on the stock exhaust manifolds? or did the spec change along the way??
Re: Sportec RS600
This is on stock manifoldsGavinda wrote:great numbers. Was this on the stock exhaust manifolds? or did the spec change along the way??
Sent from my iPhone using Tapatalk Pro
Re: Sportec RS600
Having spoken to a friend that approached MRC, the manual conversion was quoted at 15k +/-2k.
I read that MTM also did a manual conversion using the B5 RS4 gearbox (Audi Driver magazine dec 2004 issue 12)
Re: Sportec RS600
15k thats crazy. Im about to do mine . I have a 2.7tt a6 for all the running gear. Steveken adapter plate. Jhm clutch. Might add the jhm carbon synchro kit aswell. Under 3k so far. Will be doing the swap myself.
Re: Sportec RS600
Gavinda wrote:15k thats crazy. Im about to do mine . I have a 2.7tt a6 for all the running gear. Steveken adapter plate. Jhm clutch. Might add the jhm carbon synchro kit aswell. Under 3k so far. Will be doing the swap myself.
+1 to that.
Or you can switch out the crank for an S6 crank to get even more clutch options.
15k gbp is ridiculous!
You going to run an 01E?
Re: Sportec RS600
Where’s your Bread van at? You still have it?bam_bam wrote:Crank power.
Square one.
Users browsing this forum: pwack and 28 guests
