Start stop error
ics3s
Start stop error
Post by ics3s » Tue Mar 06, 2018 10:04 am
Hello guys,
Since yesterday i have 2 problems with my car(Pre FL).
In the morning i started the car and after 10-20 seconds i get an EPC light and a warning not to go over 4000 RPM.
I turn the car off and on again, error disappears but then i get Start Stop System: System fault! Function unavailable. If i turn off the Start stop error disappears.
After i drive for a little and turn the car off and on again, errors are gone.
Heard something about changing the battery.
Anyone else had this problem?
Thank you,
Radu
RS6 C7 '14
Honda S2000 '03
Infiniti FX 35 '08 (US model)
Lexus IS '06 220d (sold)
Peugeot 206 '01 2.0 Hdi (sold)
VW Touareg 2.5 R5 TDI '03 (sold)
Alfa Romeo 156 2.0 T Spark '99 (first car) (sold)
rtd
Re: Start stop error
Post by rtd » Tue Mar 06, 2018 10:49 am
I’m still having problems with my start/stop system. My issue is when the car goes into start/stop mode it will then not start properly it’s like either battery has died or it’s choking. New battery hasn’t resolved the issue so going into garage in a few weeks for further diagnosis.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
ics3s
Post by ics3s » Tue Mar 06, 2018 11:09 am
After some driving 20-30 min and turning off and on the car, start stop works normally. Witch battery did you change? As i know there are 2, the usual 12V and another 48V. And from what i heard the start stop uses the 48V.
RS6 C7 '14
Honda S2000 '03
rtd
Post by rtd » Tue Mar 06, 2018 11:12 am
I replaced from Audi with the exact same battery. I was told that putting in anything less would not do the job. So I assume it will be the 48v one which you reference.
I’ve defo go an issue with the start/stop issue but nailing it down might be a pain.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
ics3s
Post by ics3s » Tue Mar 06, 2018 11:39 am
did you also get the 4000rpm limit warning?
RS6 C7 '14
Honda S2000 '03
rtd
Post by rtd » Tue Mar 06, 2018 11:42 am
No I don’t get any warnings it just refuses to start.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
scottie1979
Post by scottie1979 » Tue Mar 06, 2018 1:46 pm
I had the start stop system error last week. Audi assist looked at it and in the end advised that there was a known TPI against it 2046732/5
I dont know the specific problem part but it was a fault with the cooling system, I was advised that in pre facelift cars a part has to be changed - post facelift (mine is) the part is already 'updated' but if the this issue occurs (again sorry cant quote the exact error thrown on VDCS) then there is no fix at this time.
In the end after a few days the warning on the dash cleared itself and the system works again.
My issue is logged and when i fix is available then i will be contacted.
Post by MikeFish » Tue Mar 06, 2018 3:44 pm
Doesn't sound like the problem here but a low battery can give a lot of random warnings. If you have a battery reconditioned then worth trying it.
ics3s
Post by ics3s » Tue Mar 06, 2018 4:53 pm
only in the morning i have the error. After that until the end of the day there are no more errors, also car runs just fine.
will go later at a friend and put the tester on it to see if there are any error codes and i'll report later
RS6 C7 '14
Honda S2000 '03
rtd
Post by rtd » Tue Mar 06, 2018 5:09 pm
scottie1979 wrote:I had the start stop system error last week. Audi assist looked at it and in the end advised that there was a known TPI against it 2046732/5
This is really help thanks will pass info to garage when car goes in
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
ics3s
Post by ics3s » Tue Mar 06, 2018 8:45 pm
So a friend put the tester on the car and there was only one error on 05.03.2018 from the Camshaft position sensor.
RS6 C7 '14
Honda S2000 '03
ics3s
Post by ics3s » Wed Mar 07, 2018 12:32 pm
So i managed to get a copy from VCDS. This is the only fault it found from auto scan.
Friend suggested its a sensor.
Address 01: Engine (------CRDB) Labels: Redir Fail!
Part No SW: 4G0 906 560 HW: 4H0 906 014
Component: 4.0l V8TFSI / H62 0012
Revision: NCH62---
Coding: 122A003265260B0A1000
Shop #: WSC 54339 002 1048576
ASAM Dataset: EV_ECM40TFS0114G0906560 001013
ROD: EV_ECM40TFS0114G0906560.rod
VCID: 6594B802E5E0720FE1E-8030
1 Fault Found:
2795 - Bank 1: Camshaft A (Intake)
P0011 00 [096] - <beep> Setpoint not Reached (Over-Advanced)
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 65900 km
Date: 2018.03.07
Time: 09:31:06
Engine speed: 1306.50 /min
Normed load value: 12.9 %
Vehicle speed: 0 km/h
Coolant temperature: 16 °C
Intake air temperature: 16 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 13.711 V
Unlearning counter according OBD: 40
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
Readiness: 0010 1000
RS6 C7 '14
Honda S2000 '03
rtd
Post by rtd » Wed Mar 07, 2018 12:44 pm
Is your car still in warranty?
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
ics3s
Post by ics3s » Wed Mar 07, 2018 12:49 pm
not anymore, 1 march was the last day :(
RS6 C7 '14
Honda S2000 '03
rtd
Post by rtd » Wed Mar 07, 2018 12:55 pm
ouch that's harsh. you could always ask audi maybe you might get some goodwill? mention how long youv'e had this issue etc?
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Users browsing this forum: No registered users and 165 guests
