Oil leak, any ideas before I get it checked?
alexc5589
Re: Oil leak, any ideas before I get it checked?
Post by alexc5589 » Sun Feb 11, 2018 4:24 pm
So I measured the o ring as accurately as possible with some verniers and contacted Polymax who recommended FKM Viton o rings for use with engine oil and high temperatures. Got them earlier this week and fitted today, so far so good. I'll keep my eye on it but assuming the leak doesn't return then that's 46p per o ring instead of £39. Finger crossed!
sweatysRS
Post by sweatysRS » Mon Feb 12, 2018 7:31 pm
Hi is this is a garage job or something that can be done yourself? Just for future reference Thanks
dhali
Post by dhali » Mon Feb 12, 2018 9:02 pm
Have you got the address and size of o rings where you got the o rings? ?
alexc5589
Post by alexc5589 » Tue Feb 13, 2018 1:45 pm
It's a fairly easy job although does involve draining the oil so gets a little messy. Once the oil is out the oil cooler hose is easily accessed from under the car. I switched the oring over and used a bit of PTFE lube to ensure it fitted smoothly.
https://www.polymax.co.uk/o-rings/rubber-viton-oring/
Size - 16.5mm ID x 2mm CS FKM (Viton) 75 ShA
(Worth noting the size I ordered is fractionally larger in CS size than the original one, this was intentional since the original one wasn't sealing!)
Time will tell if these definitely do the job but seemed worth a shot for little cost/effort. I ordered the minimum qty which was 8 orings, so if anyone needs a couple I have spares.
sweatysRS
Post by sweatysRS » Tue Feb 13, 2018 7:47 pm
Does the front bumper need to come off for any repairs to the cooler??
alexc5589
Post by alexc5589 » Wed Feb 14, 2018 8:25 am
Yes if you actually need to access the cooler, there's no space to get at it from below. No if you're only changing the orings on the hoses on the engine block end. In either case you need to take the undertray off of course.
sweatysRS
Post by sweatysRS » Sat Feb 17, 2018 11:21 am
Would a small oil leak cause the eml to come on?? Engine oil not low Thanks
coffey555
Post by coffey555 » Sat Feb 17, 2018 5:32 pm
No, you get a yellow or red warning symbol on the DIS screen if you have low oil.
Best buy a VCDS cable and run a scan for error codes.
Misano Red RS4 B7 Avant
sweatysRS
Post by sweatysRS » Sat Feb 17, 2018 9:19 pm
What if the eml has come on? Any ideas?
Jimbob71
Post by Jimbob71 » Sat Feb 17, 2018 9:41 pm
As per above you need to connect a diagnostic machine to car, could be numerous things as to why eml light is illuminated, but diagnostic will give you a code/codes and description of the fault, hope that helps.
sweatysRS
Post by sweatysRS » Sun Feb 18, 2018 10:49 am
Ok thanks. Whats the best replacement oil cooler wise? Seen genuine, radtec, aluminium???
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot], Quinten, TS811 and 75 guests
