Door Switch
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
Gee
Door Switch
Post by Gee » Thu Nov 10, 2005 1:38 pm
Hi all I've had my 2002 Nogaro Blue S3 for a month now and am loving it :D
The only thing is I have a slight problem with the door intermitently not showing closed on the dash. Where is the door swith located so I can have a look at it as I suspect that its as simple as a loose wire causing it.
Graham
Hopsta
Post by Hopsta » Thu Nov 10, 2005 10:49 pm
G with a noggy blue S3, blimey i thought i'd gone back in time ! :)
(ex-owner btw)
The info you're looking for is here..... Linkymejig
Always check your nuts before you have a play ! [img]images/graemlins/crazy.gif[/img]
moose
Post by moose » Mon Nov 21, 2005 5:21 pm
the door switch is located in the door catch, its a one piece unit containing the catch,lock,deadlock and switches,all a3,tt and s3 ( as well as vw,seat and skoda) use the same type - its common for one of the components to fail - usually water ingress is the main cause and in colder climates this can freeze and cause the door to stick, its quite easy to replace - takes about half an hour
Return to “S3 (Typ 8L) 1999-2003”
Users browsing this forum: No registered users and 13 guests
