Spare Wheel
Re: Spare Wheel
Meh, trying to find a tyre in a dusty Spanish village is half the fun of a Euro trip.
Re: Spare Wheel
FIXED
Current ride’s
Previous rides
Previous rides
Re: Spare Wheel
True dat.
Re: Spare Wheel
There must be a space saver somewhere with the correct bolt pattern and diameter that will fit over the rear brakes?
- Weiß-sechs
- 5th Gear
- Location: Everywhere & nowhere baby, that's where I'm at...
Re: Spare Wheel
It's the front brakes you'd struggle with
Re: Spare Wheel
Doesn't matter, you could always put a rear on the front the fit the spare to the rear.
- Weiß-sechs
- 5th Gear
Re: Spare Wheel
Good call....ball ache but good call
Re: Spare Wheel
Had a RenaultSport Megane with a space saver, manual said in event of front puncture place rear on front and spare on rear.
- 1st Gear
Re: Spare Wheel
This is a subject I've been thinking about recently too. My S4 has a full size spare, so the trip down to Italy wasn't a worry (in that respect).
If I take the RS6 on a long road trip, I'm going to source a standard 19" wheel, and stick it in the roof box.
2003 RS6 Avant in Ebony Black/Silver Nappa - Wagners, Millteks, MRC Stage 2 map, Bosch 044, Sports Cats, Bilsteins, Hotchkis ARBs, 390mm C6 discs, Recaro CS, RNS-E, LED tail-lights, Goodyear Eagle F1s,......Porsche filler caps
Re: Spare Wheel
<beep> sticking a full size spare in the roof box, sliding left and right as you tackle the hairpins. Those boxes are flimsy at best.
- Weiß-sechs
- 5th Gear
Re: Spare Wheel
I do it with my Vito, just pack it in well so it won't move
- 1st Gear
Re: Spare Wheel
It wouldn't be empty lol
And my Thule has been as tough as old boots for the last 11+ years.
- iaingbrown
- 1st Gear
Re: Spare Wheel
Had the misfortune of feeling a tyre 'go' on the entry to the Clyde Tunnel. Had to drive through and stop at first available safe area. Rear offside had been cut in two circumferentially. Abandoned car: Sunday and snowing. Went back on Monday and jacked car on plastic jack and left overnight. Took wheel and shredded tyre to tyre place. They had to use a grinder to remove the inner circle of tyre which was stuck fast to the inner rim. Unbelievably the OEM alloy is in one piece and unbuckled. The majority of the tyre had splayed over and protected the outer rim; the inner had a tight circle of rubber still beaded to the inner rim.Some paint damage only. Black chrome finish since you ask. All is good and car survived a day on jack without being shoved over- posh bit of Glasgow is Broomhill.
Re: Spare Wheel
I have a similar to this in all my cars along with the pump. Works perfect for fixing a normal puncture.
2003 RS6
2000 S8
1993 URS4
2003 RS6
2000 S8
1993 URS4
2003 RS6
2000 S8
1993 URS4
2000 S8
1993 URS4
Re: Spare Wheel
Strange way for the tyre to go?!iaingbrown wrote:Had the misfortune of feeling a tyre 'go' on the entry to the Clyde Tunnel. Had to drive through and stop at first available safe area. Rear offside had been cut in two circumferentially. Abandoned car: Sunday and snowing. Went back on Monday and jacked car on plastic jack and left overnight. Took wheel and shredded tyre to tyre place. They had to use a grinder to remove the inner circle of tyre which was stuck fast to the inner rim. Unbelievably the OEM alloy is in one piece and unbuckled. The majority of the tyre had splayed over and protected the outer rim; the inner had a tight circle of rubber still beaded to the inner rim.Some paint damage only. Black chrome finish since you ask. All is good and car survived a day on jack without being shoved over- posh bit of Glasgow is Broomhill.
I'm just waiting for a puncture or damage to happen. The roads around Glasgow are a disgrace. You'd get lost down some of the potholes.
Users browsing this forum: Google [Bot], philS2 and 94 guests
