Bad day. Help needed.
kvxxy
Re: Bad day. Help needed.
Post by kvxxy » Sat Dec 23, 2017 12:15 pm
Matt where did you get your regulator from?
Both my dad a retired main dealer mechanic and his friend a audi tech have told me to avoid ECP. They said they were never happy with parts quality. If I need parts now I just call TPS. Good prices and service.
That Lucas alternator on carpartsforless has a surcharge so am I right in believing that’s a recon part?
srichards
Post by srichards » Sat Dec 23, 2017 2:49 pm
I think Lucas are owned by ZF now. https://en.wikipedia.org/wiki/Lucas_Industries
benh999
Post by benh999 » Sat Dec 23, 2017 3:45 pm
I spotted that too, doesn’t physically say if it’s a new or reconditioned part on the page? :?:
Mɐʇʇ
Post by Mɐʇʇ » Sat Dec 23, 2017 4:45 pm
To be clear, I was happy with my alternator overall. I just noted it wasn't a bosch regulator and I had a spare one on the shelf I subbed in.
In general terms, you get what you pay for. I choose the brand of the part I want when I buy from ECP. For example, TRW calipers & track rod ends, Zimmerman brake disks & so forth.
You just gotta use common sense - you can't expect to pay peanuts and get top quality.
@kvxxy - it came from KMS Parts online - an ebay outfit. But was the real deal and a good price.
kvxxy
Post by kvxxy » Sat Jan 13, 2018 4:04 pm
Quick update, car is sorted. Refurbished alternator did the job. Was a pain to do in this weather on the driveway. We had 3 mechanics who flatly turn down the job lol. So many mechnics are indimidated to work on this car it’s strange! So my dad did it at the age of 62. We discovered another issue though, we think one of the coolant pipes is leaking. It’s the solid pipe on the drivers side of the head that goes to the back. That should be fun to do.
Anyway I thought I’d give a quick run down of how to do it.
Put car in service position
Remover top radiator hose
Remove top and bottom intercoolers hoses. (Top one so you can see the top of the alternator)
Undo oil cooler lines from oil cooler housing
Undo oil line brackets so the lines can be dropped and moved out of the way.
Undo tensioner and take belt off alternator pulley
Undo alternator bolts
Now pray to god if you believe in him/her/it because it is a PAIN to take out! Removing the top intercooler hose really helps because you can spray some wd40 to help loosen the corrosion. It did not wanna come out! Also make sure you remove the earth and wires befor this.
Refitting is the reversal of all that.
We also serviced the car, my old man wasn’t impressed when we changed the spark plugs because 4 were finger tight! Oh and thanks shopp for your spark plug guide.
Anyway I hope this helps if you ever have to do yours.
Thanks to anyone who’s helped.
Kully
live.marc
Post by live.marc » Sat Jan 13, 2018 8:31 pm
great write up, learning alot in these posts - just in case!! ;-)
2003 RS6 C5 Avant Black on 19's
Mɐʇʇ
Post by Mɐʇʇ » Sun Jan 14, 2018 10:45 am
I did mine the same way you've described above - however I think there's a DIY post somewhere here where you can "in theory" do it without putting the lock carrier in service position. Not tried myself.
bilko1
Post by bilko1 » Sun Jan 14, 2018 9:07 pm
Changed mine without moving the lock carrier or any radiator hoses. I had the luxury of a ramp though.
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 64 guests
