Badge Swap
RS4LAD
Badge Swap
Post by RS4LAD » Thu Dec 21, 2017 7:42 am
Guys could do with some help please,
So the b7 is going in for a full detail soon and I thought I’d put the badges back to the factory chrome badges front and back, went to my local TPS who advised me that you can’t buy the audi rings badge for the B7 RS4 front grill without buying the full grille which was coming at over 500 quid?!
So I bought the standard A4 rings badge for the front praying that it will fit. Has anyone done this and had any luck? Do I need to have the bumper removed or can I unclip it with some tools?
This is how it looks currently
Moving onto the rear, is there any sort of guide on how to place these in their original position as they currently look very off!
I bought a few other bits and bobs too and funnily enough the R8 caps were more expensive than the bloody badges combined!
Any help would be much appreciated guys
rha1209
Re: Badge Swap
Post by rha1209 » Thu Dec 21, 2017 7:47 am
RS4LAD wrote:Guys could do with some help please,
Always wondered why you °de-badge" grill rings. The best logo ever. Keep always in chrome...
Sent fra min G8441 via Tapatalk
RS4LAD
Re: Badge Swap
Post by RS4LAD » Thu Dec 21, 2017 7:50 am
I bought the car like this mate, I can see why the previous owner done it as it gives it much more of a meaner stance but personally I prefer the oem look.
jonytek
Re: Badge Swap
Post by jonytek » Thu Dec 21, 2017 8:24 am
I did try and get the front off a while back but ended up having to take the bumper off. I think others have done it but I couldn't get it off.
With the rears I marked where they are with some tape and then used a hair dryer and fishing line to get it off. If you don't think they're in the correct position there was a thread here recently with some measurements, try a search.
BUILD THREAD
IG: @bad_rs_4
Jon_J
Re: Badge Swap
Post by Jon_J » Thu Dec 21, 2017 10:58 am
Here you go:
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
Re: Badge Swap
Post by MikeFish » Thu Dec 21, 2017 10:58 am
If you are not worried about breaking a few tabs on the old black rings then it is not too difficult to remove using plastic trim removal tools or a thin screwdriver with a bit of tape around the end for protection.
Re: Badge Swap
Post by MikeFish » Thu Dec 21, 2017 11:04 am
Quite simply because it's not chrome, it's cheap plastic pretending to be chrome and looks cheap and nasty. Real chrome on a 1960s AC Cobra looks good, cheap plastic fake chrome on a noughties car looks bad. Fake chrome is a bit 80s/90s (although some of the 1980s cars probably still had real chrome.
Also, the RS range is normally devoid of any other chrome, even Audi leave it to the A and S cars and not the RS range other than the rings (and some tailpipes).
RS4LAD
Re: Badge Swap
Post by RS4LAD » Thu Dec 21, 2017 7:08 pm
Here you go:
Thanks a lot mate I appreciate it
RS4LAD
Re: Badge Swap
Post by RS4LAD » Thu Dec 21, 2017 7:11 pm
Thanks Mike, not bothered about current rings. Main concern is damaging the actual grille. Do I just simply click the new one into place mate?
Re: Badge Swap
Post by MikeFish » Thu Dec 21, 2017 7:18 pm
Yes, have you seen the back of the new one yet? It just has a series of plastic tabs that will click into place as you press it in.
RS4eddie
Re: Badge Swap
Post by RS4eddie » Sat Dec 23, 2017 1:26 am
Swapping front rings just takes a few minutes... Use a taped up screwdriver or plastic trim tool and they pop out very easily. Just be patient.. DO NOT buy a new grille!!!
2007 RS4 | Phantom Black | Milltek'ed | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | K&N Filtered | Ziza lit | Lamix-ed | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
RS4LAD
Re: Badge Swap
Post by RS4LAD » Sat Dec 23, 2017 2:17 am
Tbh I haven’t even took it out the wrapper mate I’m going to give this a shot tomorrow. But Iv got a feeling I’m going to want to put the black one back on after.
RS4LAD
Re: Badge Swap
Post by RS4LAD » Sat Dec 23, 2017 2:20 am
Yeah I will attempt with a taped up screwdriver mate thank you. Wow Why does that b7 look so beautiful :shock:
RS4LAD
Re: Badge Swap
Post by RS4LAD » Sat Dec 30, 2017 1:33 am
Did this today guys, black one came off piece of piss. However the chrome one was fidgety as <beep> to get on! Was very stiff and had to wriggle it in place there was one tab in particular at the top that took the piss! Had to gently push it down and it flew into place! Looks great now and a perfect fit.
Just to confirm then the stealers were chatting <beep> and you can just buy a standard a4 rings badge and it fits perfectly. Pic to follow when car is washed
Thanks again guys!
:thumb:
RS4LAD
Re: Badge Swap
Post by RS4LAD » Sat Dec 30, 2017 3:40 am
Part number for anybody that wants it in the future can’t remember how much it was exactly but it was around £25
Users browsing this forum: Bing [Bot], Google [Bot] and 73 guests
