Bexpro - Remote Tailgate closure module
- Surrey Sam
One of the frustrating aspects of the power tailgate, is that you can't close it via the Key.
So after many hours trying to see if there was a way to code the feature via VCDS (not possible) I found this Bexpro CTM1 module advertised. It claimed to do exactly what I wanted, which was to allow me to press and hold the key fob tailgate button for 2 sec and the tailgate then closes, it also allows you to do the same via the driver’s door switch. All for what I thought was a fairly reasonable 65 EUR.
Web link - http://shop.bexpro.co/en/tailgate-modul ... riant.html
It came very quickly from Germany and you then need to send an email for instructions, this didn't happen over the weekend just gone. But I duly received an email in the next working week with a username/password to download some German PDF documents. The email body did however contain some rough English guidelines, so a quick study of a wiring diagram to make sure and I was good to go.
All installed this evening and it works like a charm.
Edit - Video and some installation instructions are further on in this thread
Re: Bexpro - Remote Tailgate closure module
Or buy a Jag and it does it out of the box
But only if you’re in your pissy slippers.
- djcliffsmiff
Hi SamSurrey Sam wrote:One of the frustrating aspects of the power tailgate, is that you can't close it via the Key.
I found this frustrating too. I had BM before my RS4 and I could do this from the remote.
Was it hard to wire in or was it a plug in type modification? Was the wire done at the tailgate or somewhere else in the car? I take it you done it yourself?
This sounds like a 65 EUR well spent
Sent from my SM-G935F using Tapatalk
Brilliant - also interested. How handy do you need to be to install it and where does it get installed?
Current:
- Audi B8 RS4 - Panther Black
Previous:
Previous:
Is this really not possible with VCDS? I thought someone would of figured it out by now unless it is a hardware restriction.
Now if only i had a power boot lid
Look a good little mod that
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Lazy tw@ts, just use your hands. Or is it a dick swinging thing?
- Surrey Sam
Definitely supermarket carpark one-upmanship, milfs love it. On the practical side, more so at this time of year. It stops your hands getting dirty and then transferring it to trousers/steering wheel. Also if a little person gets something out the boot and can't close it, you can without having to get off the heated seat.
Technology...you C5 guys should try it.
- Surrey Sam
djcliffsmiff wrote: ↑Wed Dec 20, 2017 10:31 pmHi Sam
Hi guys.
Yes I did this myself. It's not plug and play as you need to do a little wire loom stripping, to get the right wires to tap into. But you only need to remove the rear tailgate panel to gain access, so it's not hard if you've removed trim panels before and can solder wires together. I'll pop some pictures up later today to try help people gauge if it's DIY'able or not.
Us C5 lot just take one of the gas struts off! Bingo. How do you get in the drivers door?Surrey Sam wrote: ↑Thu Dec 21, 2017 10:01 amDefinitely supermarket carpark one-upmanship, milfs love it. On the practical side, more so at this time of year. It stops your hands getting dirty and then transferring it to trousers/steering wheel. Also if a little person gets something out the boot and can't close it, you can without having to get off the heated seat.
- Surrey Sam
Little clip to show operation.
- djcliffsmiff
Surrey Sam wrote:Little clip to show operation.
- Surrey Sam
Right, got the images off my phone and created some guidelines to help anyone intrested in this.
Click on the images for full resolution:
ElsaWin instructions to remove the tailgate trim panel.
Wiring Diagram
Tailgate Switch Pinout
Tailgate Lock Pinout
Label BexPro Harness
Unravel wiring harness to expose necessary wires to splice and solder into
Solder connections - Cover your boot floor with an old rug to protect from any solder spilage otherwise it could burn through your carpet.
Connect the Black and Brown first which should power module, then connect Red to the tailgate lock wire as per diagram. Turn the ignition on and press the tailgate unlock button. The module should blink quickly as it takes the signal. Now turn the ignition off and connect up remaining wires, except the orange which should be isolated. Use good quality electrical tape to wrap solder joints.
Re-wrap wiring harness using fabric tape - Tesa manufacture some.
Re-assemble trim panel and locate BexPro module - I stuck it inside the offside rear light access hole, using a cut down double sided padded number plate Sticker.
Job done
Wiring Diagram
Job done
Users browsing this forum: No registered users and 55 guests
