Custom or off the Shelf Exhaust?
Re: Custom or off the Shelf Exhaust?
Both Classba & MRC told me not to buy them when I asked their opinion. MRC had tried to fit a set for a customer and ended up chopping them to bits to try and get close to fitting them.
Cheers Ian, yeah it required a lot of work. More than it was worth TBH
Im a bit gun shy on the coolers now....
They're "adequate" at best but a decent fabrication place in Aus should be able to knock up something better using your existing end tanks, if you can find a good core to use (which is the issue).
