Need help with some DTCs
Re: Need help with some DTCs
Post by chunky79 » Sun Nov 19, 2017 7:48 pm
Gav66 wrote:
Sun Nov 19, 2017 12:16 pm
Yes, got to agree with you as it does sound a bit far fetched but this really is a different car after the service. I mean it's just not the same as before, not only is the power down but the gear box is changing differently. I used to be able to drive in 5th at 30mph and it's deffinetly not doing that, also in the advert when I bought the car it said it had a revo switchable map ??? I have the printout from revo which shows going from 480bhp to 520 bhp.
I thought only the MRC map let you change into 5th at 30mph. Anyone of the gents with the Viper box map do this?
The box does adjust it's behaviour depending on how it's driven, but it won't lose the 5th at 30mph just like that. Strange one, I give you that.
Gav66
Post by Gav66 » Sun Nov 19, 2017 8:30 pm
Thanks for your input Chunky, really need to get to the bottom of this it's wasting my enjoyment driving the car since I know how good it did drive.
Gav.
Gav66
Post by Gav66 » Wed Nov 22, 2017 3:28 pm
Update...Been to Auto tech in port Glasgow yesterday, map is still on the engine but can't check the gearbox. Need to contact Viper and see what they say. Loss of power is a boost leak somewhere so I need to go back and have it smoked tested. Readings for the boost are down 0.5 bar, I take it that's a fair bit ?
Gav
Post by Shoppinit » Thu Nov 23, 2017 4:46 am
That sounds like a more plausible explanation for your issue. Fading maps indeed.
Standard boost is about 0.8 bar above atmospheric IIRC.
Gav66
Post by Gav66 » Thu Nov 23, 2017 9:37 am
Thanks Shopp, going back tomorrow so hopefully find the leak and happy days. Just need to find out what's happening with the box...could the boost leak affect it ?
Post by Shoppinit » Thu Nov 23, 2017 1:50 pm
Yes, it calculates shift points and stuff based on calculated engine torque which will be affected by MAF readings, etc. Sort out the leak and hopefully everything will be back to normal.
Gav66
Post by Gav66 » Thu Nov 23, 2017 4:16 pm
Ben_r1
Post by Ben_r1 » Fri Nov 24, 2017 11:36 pm
Can someone explain the engine mount setup please? I've seen the sensor located on them, how does this affect the dampening properties of it?
I can't see any additional pipe work to pump up the pressure and such.
iconic78
Post by iconic78 » Fri Nov 24, 2017 11:44 pm
Ben_r1 wrote:Can someone explain the engine mount setup please? I've seen the sensor located on them, how does this affect the dampening properties of it?
RS4’s have electrohydraulic engine mounts with oil inside and electronic valving to restrict the oil flow. This is done by electronic pulses from the ecu depending on engine load etc
These are sealed units so no pipes.
Ben_r1
Post by Ben_r1 » Tue Nov 28, 2017 7:37 pm
Do they commonly fail or reliable with mileage?
Post by Shoppinit » Wed Nov 29, 2017 4:40 am
They fail frequently.
Ben_r1
Post by Ben_r1 » Wed Nov 29, 2017 8:39 am
lol there's a surprise. I'm starting to see how Audi ownership works, if it's fitted to the vehicle it will at some point break
bilko1
Post by bilko1 » Wed Nov 29, 2017 1:39 pm
When I first got my 6 it had a DNA map on the TCU which would change in to 5th at 30 mph. I'd never heard of DNA so promptly took it to MRC.
Users browsing this forum: srichards and 91 guests
