Exhaust Noise ....
5.0 V10 50v biturbo - 571 bhp
rs6_sid
Re: Exhaust Noise ....
Post by rs6_sid » Fri Nov 10, 2017 9:58 am
turbos are your issue , they kill sound and muddy up the sounds you hear from the engines firing order.
c6 rs6 avant- mrc stage 2 -current
bmw e61 m5 saloon
s3 8p stage 2
vw bora tdi hybrid turbo
Jess
Post by Jess » Fri Nov 10, 2017 1:28 pm
rtd wrote:
Fri Nov 10, 2017 7:29 am
Common misconception but the V10 in the RS6 is substantially different to the Lamborghini unit
Is the firing order the same do you know ? I also read it has 400 unique parts, but also has a lambo bull stamp on the block somewhere etc..
It must be the turbo's that dull the sound
rtd
Post by rtd » Fri Nov 10, 2017 1:30 pm
Not sure on firing order IanH will be along to answer that but Bull stamp on block is correct I believe that is the only Lambo connection!
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
IanH755
Post by IanH755 » Fri Nov 10, 2017 1:52 pm
As RTD said, only the bare block is the same (with it's Lambo marking still there), every single thing else (crank, pistons, rods, valves etc) is all custom to the RS6 and all those changes effect the sound the engine makes, plus the turbos heavily muffle/chop-up/blur the firing order sound too (which is 1 - 6 - 5 - 10 - 2 - 7 - 3 - 8 - 4 - 9).
For the "closest to Lambo" sound you're after you'd really need the 5.2L V10 S6 with a custom exhaust (and "maybe" a set of manifolds too) rather than the RS6.
There's a really good RS6 study guide on the web which I posted a link to here - viewtopic.php?f=47&t=121159&p=805291&hi ... dy#p805291
julianmalc
Post by julianmalc » Mon Dec 11, 2017 12:25 pm
I have a full supersprint system including cat delete pipes on my saloon, also has MRC stage two, sounds loud and punchy on full throttle with gear change snort just like the videos, no drone, but on part throttle is less intrusive around town. it is are expensive. but very pleased with my system
