Headlight re-alignment after lowering?
max_b
Post by max_b » Thu Nov 09, 2017 11:53 pm
Is this something that is required?
I've got a slight flickering of the headlights within the first few minutes of use then they settle down to normal without issue.
Only started after suspension replacement/lowered ride height
:beerchug:
RS4.....another :-)
Previous - all sorts
Jon_J
Re: Headlight re-alignment after lowering?
Post by Jon_J » Thu Nov 09, 2017 11:55 pm
My understanding is they are self levelling.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
FaisalJ
Post by FaisalJ » Fri Nov 10, 2017 9:15 am
Perhaps just a bulb on its way out?
I've only ever had one xenon bulb fail on me - flickering first, then it started lighting up purple at startup.
2007 RS4 B7 Avant
Davidol
Post by Davidol » Fri Nov 10, 2017 11:32 am
Flicking is normally bulbs on its way out as Faisal has said. Normally a good idea to replace them both as typically if one is going the other won't be far behind and it's a bumper off job to change the bulb. Osram can be had for around £100 a pair
lushman
Post by lushman » Fri Nov 10, 2017 9:38 pm
I had exactly the same issue and a new set of bulbs as mentioned cured the issue for me.
2006 B7 RS4 Avant Sprint Blue & Black Optics
2000 Avus Silver B5 RS4 - Gone
Grandadg90
Post by Grandadg90 » Sat Nov 11, 2017 10:00 am
It can be done without the bumper being taken off and headlights in situ. Just requires a bit of patience.
Daytona Grey, Bilstein Coilovers, Pre-cat delete, Centre resonator delete, IM flaps/vains delete, Interior/Exterior LED kit, CAI, Black Optics.
Other car: Bread Van
Covkiller
Post by Covkiller » Thu Nov 16, 2017 4:15 pm
And small hands
Jon_J
Post by Jon_J » Thu Nov 16, 2017 4:42 pm
Like Beadle!!!
Take the bumper off, it’s not that hard
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Users browsing this forum: No registered users and 92 guests
