Correct steering position sensor?
Hello, is J0 959 654AG the correct number I need for the rs6 c5? Trying to find the right answer everywhere and that seems to be the right one but I can't confirm it.
Thanks, Adam
Thanks, Adam
Re: Correct steering position sensor?
Are you missing a digit from the front of that part number?
1 J0 959 654AG is the full code. Sorry didn't realise the 1 was pat of it
1J is Golf platform isn't it? Might be the same part. Sometimes they mix it up a bit, but not generally on parts like that.
Looks like the part number is either:
1J0 959 654AG
1J0 959 654AL
1J0 959 654M
Depending on your option codes.
Why are you replacing it?
1J0 959 654AG
1J0 959 654AL
1J0 959 654M
The M is for cars with tiptro controls on the wheel. 4 spoke Multifunction steering wheel. Not sure about the other two. Just looking.
AG:
2ZS = Leather trimmed multi-function steering wheel with Tiptronic
2FL = Leather trimmed multi-function steering wheel with Tiptronic
AL:
2ZD = Heated leather trimmed multi-function steering wheel with Tiptronic
2FK = Heated leather trimmed multi-function steering wheel with Tiptronic
M:
1MU = Leather trimmed sports steering wheel for air bag system with Tiptronic
1XY = Leather trimmed multi-function sports steering wheel w/ Tiptronic
AL:
M:
The clock spring got turned one too many times when I had my new rack fitted so I've got abs, esp and airbag lights, no flappy paddles and sometimes no horn. I've just got the standard rs6 leather wheel.
It sounds like AG is the right one, I'll get a m12 spline socket over the weekend and double check as I don't want to get it wrong
You got the 4 spoke multi-function steering wheel then? Welcome to the exclusive club of hi-spec RS6s.
Also came with free slippers , pipe and a travel pack of Werther's Originals .
Cheers Al
Sadly not, just the normal 3 spoke one. would be they handy if it was a 4 spoke, with volume controls in easy reach.
If you've got the 3 spoke then it looks like you need the M version, neh?
Misunderstood the "multi function" bit. If that is the case that it an "M" one, that's half the price I was going to payfor one, which is awesome.
Users browsing this forum: No registered users and 83 guests
