01543 parking aid warning chime fault
when i put the car in reverse i get a long beep from the front (dash) of the car and the P light flashes constantly
did a scan and i get
01543 parking aid warning chime (h15) 31-00 open or short to ground
google is scetchy one thread says its the beeper in the parcel shelf of the boot?
any ideas?
any ideas?
- PetrolDave
Re: 01543 parking aid warning chime fault
Google is right - there's a beeper under the parcel shelf that normally sounds when you're reversing and get close to an object. That beeper (or the wiring to it) is faulty.Rick_RS4 wrote:when i put the car in reverse i get a long beep from the front (dash) of the car and the P light flashes constantly
any ideas?
Carried any large loads recently in the boot that may have disturbed the wiring?
I have the same issue, seems to come and go though :/ will get it checked out next time I'm at Audi
RS3 8P 2013 Phantom Black with Ally Pack and Black Optics Grille | LED Interior and number plate lights - GONE
RS4 B7 2006 Phantom Black with Titan alloys and mirrors - GONE
no, boot is always empty, ill take a look for the beeper tomorrow, it has only just started doing it constant, before if i put it in reverse then out and back in it would clear.PetrolDave wrote: Google is right - there's a beeper under the parcel shelf that normally sounds when you're reversing and get close to an object. That beeper (or the wiring to it) is faulty.
klauster wrote:I have the same issue, seems to come and go though :/ will get it checked out next time I'm at Audi
mine was intermittant too, now its all the time
ahh its quite annoyin when it does it, let me know what you find out plsRick_RS4 wrote:no, boot is always empty, ill take a look for the beeper tomorrow, it has only just started doing it constant, before if i put it in reverse then out and back in it would clear.PetrolDave wrote: Google is right - there's a beeper under the parcel shelf that normally sounds when you're reversing and get close to an object. That beeper (or the wiring to it) is faulty.
ordered a new speaker yesterday, fitted tonight and all working as it should again thank god, very annoying.
you dont realise how much you use the sensors
the speaker was £14, i think the cheapest part i have bought for the car
Been a while I realise but could you let me know where abouts the speaker is and how to get to it - I think may failed the other day as it crackled for a bit and now I get the same long beep and flashes as you describe.
did u find were its located i think its in the left hand side conpartment in the boot
Hi,
Can you confirm where this is buzzer is located under the parcel shelf. I have the same fault it seems fairly common!
Tom
Tom
Users browsing this forum: Bing [Bot], Google [Bot] and 124 guests
