RS6 C6 2008 - OEM part number for headlights
All
I’m considering replacing both my head lights as they at in a poor state.
So I order the right lights, does anyone have the part numbers?
Also, is it a bumper off job to fit them?
PJ
PJ
Re: RS6 C6 2008 - OEM part number for headlights
I had one changed by QST - if I recall, it IS a bumper off (I may be wrong)...and very expensive!
Yeap, bumper off to fit/remove them but they are extremely expensive, IIRC they are around £1000 each for new ones or £300-ish for 2nd hand!!!
LH Light - 4F0941029CK
RH Light - 4F0941030CK (or 4F0941030FB as the CK number may not be available now)
However, with the huge cost I'd go into Audi with your chassis number instead (found on the left side of the windscreen) just to make 100% sure you get the right ones, just in case the website I linked below is wrong.
Here's the site I use for part numbers - http://www.oemepc.com/audi/main_group/m ... 641/lang/e
I would get in touch with Trups, when he was working on upgrading the lens I am sure he mentioned that he had found a source for new front glass, best to check with him!
At the time I got my local guy to refinish the headlights while they were off the car once Trups had done his magic, the before image isn't great but they still look good today;
Esben Business IT Solutions - http://www.esben.co.uk
Esben Remapping - http://remap.esben.co.uk
2015 BMW X6 M50d (wife-transport, not allowed to touch
2008 RS6 Avant Phantom Black - MRC Stage2 (ecu, tcu & 2nd cat bypass) 730 PS/1017 nm
2006 BMW 535d Pre-LCI - Stage 1 (340bhp)
2003 VW Polo 1.4Tdi (3pot shitbox) tuning project, was 73bhp, now 120bhp, aiming for 160bhp before it goes bang! (put in the bin)
Whats the problem with the Lamps PJ?
Trups
Trups
Trups, the lens is in an awful state and strangely looks like there’s some discolouration on the inside. If the lens can be replaced, result!
If there’s a way to refurbish them I’m all ears!
HI.
I can supply brand new lens, Clean the insides down, I can also do a few mods inside to get the headlights performing 20 times better than what they do as the projectors in them are not great. Before I would put a new projector in the fog light housing, now I can also change out the OEM projector fully to have a better one in there if you wanted the untouched look,
If any of the chrome has peeled from moisture inside then there is no saving that I'm afraid, I have seen it before.
I would need the headlights sent into to me for the work to be carried out or the car can be left and I can do a drive in/ drive out service.
trups
trups
PM sent!
