Potential issue with coolant hose rupture (Facelift RS6)
Leo-RS
Re: Potential issue with coolant hose rupture (Facelift RS6)
Post by Leo-RS » Mon Jun 19, 2017 7:00 am
TRS6 wrote:
Fri Jun 16, 2017 12:47 am
Apologies for amateur hour over here...
But could someone post a better picture and arrow specific to the part I should be looking at adjusting?
Can't make out exactly on mine where/what I should be looking at.
Hoping someone could help this oxy moron here.
A is Coolant Pipe
B is Firewall Bulkhead panelling
The horizontal red line is the gap between the coolant pipe and the clip that holds the firewall panelling together
The solution is to force the clip further down (Indicated by red arrow) - This naturally increases the clearance between the coolant pipe and the bulkhead panelling. I just used a flat bladed screwdriver to force the clip further down.
Under hard acceleration the engines moves back and the clip has the potential to puncture a hole in that coolant pipe.
The location as you open your bonnet (hood if you are in the US) is back centre/left of engine bay by the rear bulkhead.
MY16 Audi RS6
Post by MikeFish » Mon Jun 19, 2017 8:49 am
It's at the back of the engine bay / in front of bulkhead.
If you have the bonnet up, as you are looking at the engine it is right at the back wall just a little to the left of the big engine cover. Probably not far off from the spindle for the drivers windscreen wiper.
Open the bonnet and look for this:
TRS6
Post by TRS6 » Tue Jun 20, 2017 1:42 am
A is Coolant Pipe
Absolute legend!
Thank you and appreciated.
Current Cars:
2018 991.2 GT3 - Carrara White
2010 997.2 GT3 - Carrara White (Sold)
1982 911 Carrera RSR IROC - White
2016 RS6 PE - Nardo Grey
2016 Audi A1 S-Line - White
mikeylcr
Post by mikeylcr » Thu Oct 05, 2017 1:01 pm
Hi, and apologies for the lurking! Does anyone have a pic as described above? being very ignorant of anything more technical than my oil, washers, tyres and the throttle pedal I can't identify the bits in question, the helpful one above has fallen victim to the t**ts at photobucket!
Post by MikeFish » Thu Oct 05, 2017 4:08 pm
When I click on the photo above on my phone it still shows me the original photo.
mikeylcr
Post by mikeylcr » Fri Oct 06, 2017 1:32 pm
Thanks for that, bizarrely it does the same for me, doesn't work on pc but does on the phone
batmanreturns
Post by batmanreturns » Tue Jan 29, 2019 7:42 am
Can someone repost this as the photo has gone and clicking on the photo as some people have said just brings up the same ‘photo has been removed’ message. Thanks
Post by MikeFish » Tue Jan 29, 2019 8:52 am
I can still see the original photos. Did you try looking using your phone?
Eddie555
Post by Eddie555 » Tue Jan 29, 2019 9:23 am
It’s still on page 1 using a phone. But here it is anyway. I’ve just screen shot them.
Current ride’s
Previous rides
batmanreturns
Post by batmanreturns » Tue Jan 29, 2019 4:52 pm
Thanks but what I ideally need is arrows to what I’m supposed to be looking for as the photos just show pipes and jubilee type clips, im confused if it’s those or something else hencing wanting a diagram on a photo! I know I’m high maintenance! Thanks
Post by MikeFish » Tue Jan 29, 2019 5:43 pm
In the top photo there are 2 bits of metal attached to what looks like a metal wire running across the photo. Make sure the one on the left isn't touching the coolant hose in front of it.
jwlanky
Post by jwlanky » Fri Feb 01, 2019 11:55 am
It sure wouldnt hurt this being made a sticky - as this potential issue passed me by until today! Thanks op :thumb:
rs4AAK
Post by rs4AAK » Fri Feb 01, 2019 12:21 pm
I sorted mine out last night. A deeping droove was present in the pipe after 20k. Thanks :thumbs:
jwlanky
Post by jwlanky » Mon Feb 04, 2019 3:57 pm
I checked mine which seemed fine.
[attachment=0]2019-02-02 11.31.25.jpg[/attachment
X44ASM
Post by X44ASM » Fri Jun 28, 2019 7:27 pm
I just checked mine on my 2017 Performance and found it to be rather close around the 5-6mm. No markings on the hoses which is good news but I’m so glad I read up on this as it definitely looked close enough that it could have rubbed.
:notworthy: Thankyou to the OP
Users browsing this forum: Daveperc and 70 guests
