This. You'll only need it on the front two doors. You'd need a pick-axe to get through the front windscreen.MikeFish wrote: ↑Mon Oct 02, 2017 5:41 pmI would also fit some security film to the insides of the windows, as this should stop them even being able to get into the car to steal the seats and stop a lot of the damage that happens from breaking in and stealing ie the door cards damaged, seats ripped etc.
Attempted seat theft?
Re: Attempted seat theft?
@jon_j I just locked mine as usual from the button and it's dead locked straight away even tried with windows down and tried lock unlock button from inside wouldn't open... didn't realise the seats could be taken out of window
It was this one - http://www.clifford.co.uk/Factory_Upgrades.html Seems pretty good to me if I put the wipers down too hard when washing the car it chirps a warning. The only downside is they had to disable the Audi interior sensors so the door LED flashes a warning but has been perfect for 4 years or so now. If you are in Hampshire/Dorset area I can recommend the installer who came to me.A20LEE wrote: ↑Mon Oct 02, 2017 5:55 pmWhich Clifford did you fit? I'd like an upgrade which keeps the factory key for arm and disarmMB2 wrote: ↑Mon Oct 02, 2017 5:27 pmI did the following to protect my seats -
1 - Upgraded to Clifford alarm - it isn't the most sophisticated out there but it has its own interior sensors, blue dash LED and loud siren. I chose that one as it meant I kept the standard remote key to arm/disarm the alarm
Green Loctite is very strong - you need a lot of heat to break the bond it makes. Yes, undo each bolt, degrease, few drops of Loctite and tighten up again. I wanted to keep the OEM bolts for safety in an accident - there is one that is hard to get to so I didn't Loctite that one as thought it would end up preventing me getting the seats out !Rjhenderson22 wrote: ↑Mon Oct 02, 2017 6:00 pm
It sounds like some people have welded the seat bolts and filled with epoxy. For those who have - details of where and how much would be great. If extortionate it sounds like Loctite is a good option. I assume this is taking the bolts out, coating and tightening again?
FYI - I would be interested to know what the benefits were and if there was a GB on the go I'd be in.
Ah - I would expect the lock unlock button to work. Leave the window open, lock it with the fob, reach in and try the inside door handle.m5killer wrote:@jon_j I just locked mine as usual from the button and it's dead locked straight away even tried with windows down and tried lock unlock button from inside wouldn't open... didn't realise the seats could be taken out of window
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
That's a shame, the Viper leaves the standard alarm intact, doesn't affect it at all, you just have two instead of one.MB2 wrote:It was this one - http://www.clifford.co.uk/Factory_Upgrades.html Seems pretty good to me if I put the wipers down too hard when washing the car it chirps a warning. The only downside is they had to disable the Audi interior sensors so the door LED flashes a warning but has been perfect for 4 years or so now. If you are in Hampshire/Dorset area I can recommend the installer who came to me.A20LEE wrote: ↑Mon Oct 02, 2017 5:55 pmWhich Clifford did you fit? I'd like an upgrade which keeps the factory key for arm and disarmMB2 wrote: ↑Mon Oct 02, 2017 5:27 pmI did the following to protect my seats -
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Given the interior sensors are easily disabled I don't see it as s great loss vs the convenience of the OEM keyfob. The door LED still flashes - it just lights solid for 30 seconds or something first to indicate a fault.
It requires a lot of skill and a disregard for the rest of the car to get 2 seats out of a window without getting caught. I've had my seats in and out the of the car a few times with the doors open and it's a struggle, they weigh a ton and are quite large. I'm amazed how they manage to get them out.
I would also be interested in the alram GB if there is one, as i do not want this happening to mine an also just been supercharged dont want the car going aswell, would like a anti car jacking system adding in to it aswell if possible ( already been a victim of this in a s3)
Sorry to hear about your seats - I had the same and they even nicked the gear stick knob. I got an upgraded alarm etc and also had bolts made with a unique fitting - it wasn't that expensive in the scheme of things.
I am going to get in touch with securemycar today with some initial numbers - are any more people keen?
So far we have:
1) me
2) 8utters
3) Lukes3
4) Mav8
So far we have:
1) me
2) 8utters
3) Lukes3
4) Mav8
For anyone interested, this makes interesting (sobering) reading
https://www.secureyourcar.co.uk/audi
There is a company doing a new system that before you turn on your car you enter a code via the buttons on your steering wheel. Like a pin for your mobile. You choose the sequence and you cant start without it.
https://www.facebook.com/carthrottle/vi ... 313355344/
Users browsing this forum: Google [Bot], kerraddoo01 and 128 guests
