Manifold flap delete
maizyboy
Post by maizyboy » Wed Sep 20, 2017 10:36 am
Anyone have experience of manifold flap deletion ? Booking mine for a carbon clean, getting EPC light regularly, thinking it might get the deletion kit while the manifold is off anyway. What's the feedback ?
Current : Sprint Blue B7 RS4 avant.
Previous: Sprint Blue B7 S4 saloon, Nogaro Blue B5 S4 saloon, Porsche Boxster, Audi Coupe S2, Audi Coupe 2.8E
Grandadg90
Re: Manifold flap delete
Post by Grandadg90 » Sat Sep 23, 2017 4:28 pm
You will need a remap after though.
Daytona Grey, Bilstein Coilovers, Pre-cat delete, Centre resonator delete, IM flaps/vains delete, Interior/Exterior LED kit, CAI, Black Optics.
Other car: Bread Van
maars
Post by maars » Sun Sep 24, 2017 12:19 am
What’s the benefit of doing the mod?
Daytona RS4 Avant - black optics/decat downpipes/H-pipe/KW springs - featured on the 2012 Audi stand at the Goodwood FoS
iconic78
Post by iconic78 » Sun Sep 24, 2017 10:53 am
More torque at the top end and you won’t lose the flaps as they known to come loose.
maars
Post by maars » Sun Sep 24, 2017 8:24 pm
Ok. So how do they work normally?
Davidol
Post by Davidol » Sun Sep 24, 2017 10:15 pm
Is there a trade off? Lose of low down torque when removed?
Rodney007
Post by Rodney007 » Mon Sep 25, 2017 9:46 am
Just had mine done. During carbon cleaning they discovered one the the flap arms was broken. The plastic joint had fractured and is quite common to break which meant only one banks flaps where opening and the other was stuck about half way.
So they commonly remove them. ECU remap is not Required but recommended. ECU will not throw a code as the actuators still move but dont move anything.
They then close the holes with frost plugs.
I also had my primary and secondary cats removed and disabled and then a full ECU remap with dyno tune. All up I gained about 30HP but inxluded carbon clean, cats and deflap (with oil change and new plugs)
Slight loss of HP down low. Slight increase uptop.
Hope that helps
iconic78
Post by iconic78 » Mon Sep 25, 2017 10:10 am
Rodney007 wrote:Just had mine done. During carbon cleaning they discovered one the the flap arms was broken. The plastic joint had fractured and is quite common to break which meant only one banks flaps where opening and the other was stuck about half way.
Hope that helps
Did they remove the arms or just the flaps?
Rodney007
Post by Rodney007 » Tue Sep 26, 2017 3:19 am
Arms and flaps.
FaisalJ
Post by FaisalJ » Tue Sep 26, 2017 9:12 am
The downside is that acceleration is lumpy until the car is warm. Feels like there's a misfire sometimes, but no issues once warmed up
2007 RS4 B7 Avant
Rodney007
Post by Rodney007 » Wed Sep 27, 2017 7:45 am
Not for me? Maybe its ur car
Covkiller
Post by Covkiller » Wed Sep 27, 2017 11:50 am
Mine is only lumpy for a few mins on cold start.
Grandadg90
Post by Grandadg90 » Wed Sep 27, 2017 8:02 pm
Faisal, has your car been remapped.
Rodney007
Post by Rodney007 » Fri Sep 29, 2017 8:00 am
Flap remove will lower the cold start idle level. The cold start RPM pickup is mainly the flap positioning choking the intake. Which i confirmed with the tuner after the mod was done. Rpm on cold start only goes to 1200rpm
Mine doesnt have any lumps. Runs smooth cold or hot after flap delete.
pule333
Post by pule333 » Sat Sep 30, 2017 9:08 am
FaisalJ wrote:The downside is that acceleration is lumpy until the car is warm. Feels like there's a misfire sometimes, but no issues once warmed up
I have that even with the flaps. Although I did remove separators
RS4 B7 aka Vinnie
Users browsing this forum: No registered users and 178 guests
