Manifold flap delete
Anyone have experience of manifold flap deletion ? Booking mine for a carbon clean, getting EPC light regularly, thinking it might get the deletion kit while the manifold is off anyway. What's the feedback ?
Current : Sprint Blue B7 RS4 avant.
Previous: Sprint Blue B7 S4 saloon, Nogaro Blue B5 S4 saloon, Porsche Boxster, Audi Coupe S2, Audi Coupe 2.8E
Re: Manifold flap delete
You will need a remap after though.
Daytona Grey, Bilstein Coilovers, Pre-cat delete, Centre resonator delete, IM flaps/vains delete, Interior/Exterior LED kit, CAI, Black Optics.
Other car: Bread Van
What’s the benefit of doing the mod?
More torque at the top end and you won’t lose the flaps as they known to come loose.
Ok. So how do they work normally?
Is there a trade off? Lose of low down torque when removed?
Just had mine done. During carbon cleaning they discovered one the the flap arms was broken. The plastic joint had fractured and is quite common to break which meant only one banks flaps where opening and the other was stuck about half way.
So they commonly remove them. ECU remap is not Required but recommended. ECU will not throw a code as the actuators still move but dont move anything.
They then close the holes with frost plugs.
I also had my primary and secondary cats removed and disabled and then a full ECU remap with dyno tune. All up I gained about 30HP but inxluded carbon clean, cats and deflap (with oil change and new plugs)
Slight loss of HP down low. Slight increase uptop.
Hope that helps
Hope that helps
Did they remove the arms or just the flaps?Rodney007 wrote:Just had mine done. During carbon cleaning they discovered one the the flap arms was broken. The plastic joint had fractured and is quite common to break which meant only one banks flaps where opening and the other was stuck about half way.
Hope that helps
Arms and flaps.
The downside is that acceleration is lumpy until the car is warm. Feels like there's a misfire sometimes, but no issues once warmed up
2007 RS4 B7 Avant
Not for me? Maybe its ur car
Mine is only lumpy for a few mins on cold start.
Faisal, has your car been remapped.
Flap remove will lower the cold start idle level. The cold start RPM pickup is mainly the flap positioning choking the intake. Which i confirmed with the tuner after the mod was done. Rpm on cold start only goes to 1200rpm
Mine doesnt have any lumps. Runs smooth cold or hot after flap delete.
I have that even with the flaps. Although I did remove separatorsFaisalJ wrote:The downside is that acceleration is lumpy until the car is warm. Feels like there's a misfire sometimes, but no issues once warmed up
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 193 guests
