RS6 Hot Start Issues
5.0 V10 50v biturbo - 571 bhp
Adam1411
Post by Adam1411 » Wed Sep 06, 2017 2:09 pm
Wondering if anyone has come across this before.
The car starts perfectly from cold but once its been run for around 30 minutes and left when i come to start it when its still warm its very sluggish and smells strongly of fuel it does eventually start but take 3-4 attempts before it eventually fires.
Any help would be greatly appreciated
Quattro_RS6
Re: RS6 Hot Start Issues
Post by Quattro_RS6 » Wed Sep 06, 2017 2:28 pm
It may be your cam angle position sensor that is starting to act up.. I know that a faulty sensor like that can give similar symptoms.
2013 Audi Q7 3.0 TDI - Family car
2008 Audi RS6 Avant V10 TFSI - Phantom black, ceramics, ACC, softclose, 21" MTM, MTM springs, MTM Cat back.
2003 VW Bora 1.9TDI Highline - Daily beater
1991 VW Golf cabriolet G60 & 1963 Ragtop T1 beetle, forever lasting project (started in 1998)
X 2007 Audi S8 V10 // 1998 Audi A6 2.5TDI Quattro // 2001 Audi RS4 MTM // 2000 Audi A6 2,7 BiTurbo Avant // 1996 Audi RS2 // 1991 Passat Syncro G60 Turbo
Adam1411
Post by Adam1411 » Wed Sep 06, 2017 2:48 pm
Thanks do you have an idea on what fault code it would throw if this was the issue as i cannot seem to figure out what the fault code it shows means
don0301
Post by don0301 » Wed Sep 06, 2017 2:50 pm
Have you got a Ross Tech VCDS to plug in?
What fault code(s) did you get?
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Belmont SRi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
1st car Datsun 120 FII Lime green....yeah :shock:
Adam1411
Post by Adam1411 » Wed Sep 06, 2017 5:15 pm
The codes that I got on my reader was 006435
douglas96
Post by douglas96 » Wed Sep 06, 2017 7:25 pm
http://wiki.ross-tech.com/wiki/index.ph ... 923/006435
That code is just a note to check the DTC memory of the engine ECU number 2. Check for codes in "Engine II" or whatever it's named in your code reader.
VCDS is definitely a worthy investment.
Adam1411
Post by Adam1411 » Tue Sep 26, 2017 9:07 pm
Only just managed to get the car read properly it showing up fault code p2190-008 bank 2 system too rich at idol
Vieussuex*
Post by Vieussuex* » Sun Nov 19, 2017 8:09 am
Adam did you end up finding out what your misfiring issue was?
I've got the exact same issue and have changed plugs, cleaned my MAP sensors etc and it still comes up occasionally.
I did change the petrol station i was getting fuel from and seemed to help and then it came back.
My issue seem to only come up when on low fuel loads such easy highway driving or light throttle
I have a service coming up soon and will be replacing air filters, spark plugs and core packs to see if resolves the issue. If not I'm starting to think I have a dirty or old injector on the way out and I believe you cannot replace one injector but a full set of 10 as they are matched from the manufacturer.
I did read somewhere that it also could be a dirty old fuel filter but believe the filter is part of the pump in the tank...can anyone confirm?
Current:-
2009 C6 RS6 Avant - Stock
Previous:-
2001 B5 S4 Avant - Stg 3
2001 S3 8L - Stg 1
1999 Golf VR6 -Stock
2004 Evo 8MR - Stg 2
2007 VW Polo Gti 9N3 - Stg 1
2006 VW Polo Gti 9N3 - Stg 2
2000 DC2 Type R
Audi-RS6-R
Post by Audi-RS6-R » Sun Nov 19, 2017 3:53 pm
1st change fuel filter - it's a seperate part on passenger side - located between back door and wheel. When this don't help...you have to change the injectors. That's what I have done a couple of months ago...
CHEQUERED
Post by CHEQUERED » Wed Nov 22, 2017 5:06 am
sounds like lazy 02s if its light load and highway driving.
Vieussuex*
Post by Vieussuex* » Tue Dec 19, 2017 4:07 am
O2s are A OK, seems to be it's an injector issue but would assumed any stage 1,2 or 3 cars will decrease the life expectancy of their o2s with pushing richer and hotter exhaust gasses pass them.
Audi-RS6-R, did you by any chance have a part number for your injectors. I'm wondering if they are the same a the C6 S6? If so I may order some from ECS.
https://www.ecstuning.com/b-genuine-vol ... 6e906036c/
Current:-
Previous:-
2001 S3 8L - Stg 1
2000 DC2 Type R
Vieussuex*
Post by Vieussuex* » Sun Dec 24, 2017 9:39 pm
After some research it looks like the part number for our injectors is 079906036C and manufactured by Hitachi as OEM.
The Hitachi injector can also be found in the following models too
A6
A8
Q7
R8
S5
TOUAREG
...no need for the RS tax.
Current:-
Previous:-
2001 S3 8L - Stg 1
2000 DC2 Type R
DJ Kill
Post by DJ Kill » Wed Dec 27, 2017 6:52 pm
Do you have normal VCDS?
You need to measure the fuel pressure in high pressure contour. After turning on ignition (w/o engine start) it should rise. If not - injectors are leaking. If it rise - this is not an injector problem and better to check sensors.
Vieussuex*
Post by Vieussuex* » Thu Dec 28, 2017 11:03 am
Yes I have VCDS, but had the car in for a major service just before going on a road trip.
I had new spark plugs, coil packs and fuel filter installed as well as a carbon clean and the injectors serviced too.
Five of the ten injectors were found to be leaking but only very slightly and the mechanic confirmed this was causing the misfire on idle and low throttle loads as well as a tonne of carbon build up.
I hastley opted to stick with the old injectors only as I needed the vehicle a couple of days later for the road trip and my mechanic confirmed it would be fine to use but would slowly get worst and I'd need to replace all ten in the next 12 months.
Since the service the car hasn't thrown any CEL's so fingers crossed it hold out at least for another 6 months.
Will continue to monitor but have to say the car runs super smooth on idle now and a lot more responsive since all the work has been done.
Current:-
Previous:-
2001 S3 8L - Stg 1
2000 DC2 Type R
Adam1411
Post by Adam1411 » Wed Jan 10, 2018 12:56 pm
I changed the cam sensor and that has fixed the problem
