Anyone help!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
kamming
Anyone help!
Post by kamming » Wed Oct 19, 2005 3:05 pm
I had vag com my car today and found below fault codes:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
My car is MY00 S4 manual.
Any one can tell me what has happened? Thank you.
KayGee
RE: Anyone help!
Post by KayGee » Wed Oct 19, 2005 4:02 pm
Top one is the coolant sensor (about £15.00 and 15 mins to fix), that code generally means it is going to fail soon.
The second one usually means you have a boost leak, have a look at your TBB, dump valves etc....
kamming
Post by kamming » Thu Oct 20, 2005 2:46 am
Thank you.
Dippy
Post by Dippy » Thu Oct 20, 2005 1:59 pm
Doesn't 17963 actually point to a wastegate or N75 problem?
2001 Silver S4 Avant
KayGee
Post by KayGee » Sat Oct 22, 2005 3:52 am
Could be an N75, however I'd check TBB, F hose (might have one MY00?) then recircs. If these are all OK, find someone to pressure test it. If all OK then move to N75.
