Just a remark: Audi has a new map from may 2017 correcting the misfire.MikeFish wrote: ↑Fri Aug 11, 2017 8:05 pmThe PE uses different spark plugs to the non PE. Also all RS6 suffer from high misfires although most of the time it goes unnoticed. I thought Audi change the spark plugs as a cure. I assumed they were rolling out the PE plugs to the non-PEs becuase of this but maybe it's not the case, maybe they are changing PE plugs to a different type too. When MRC tune this engine they change the spark plugs to a different type.
spark plugs
- 1st Gear
Re: spark plugs
Re: spark plugs
Not heard this before Mike. I get some very slight, occasional, stutters, usually at a constant motorway speed. I'd always assumed it was switching from 4 to 8 cylinders? FYI I have a PE.MikeFish wrote: ↑Fri Aug 11, 2017 8:05 pmThe PE uses different spark plugs to the non PE. Also all RS6 suffer from high misfires although most of the time it goes unnoticed. I thought Audi change the spark plugs as a cure. I assumed they were rolling out the PE plugs to the non-PEs becuase of this but maybe it's not the case, maybe they are changing PE plugs to a different type too. When MRC tune this engine they change the spark plugs to a different type.
Polo 895cc 81|Datsun thing 83|Astra Van 1.3 85|Escort 1.6 87|XR2 88|Renault 5 Trbo 90|Renault 21 Trbo 93|XR2i 16v 94|Jag XJ6 99|BMW M3 E36 01
BMW 328i E46 04 & Honda VFR750|BMW M3 E46 06|Jag XK8 07 & Honda CBR600RR|BMW 645CSI E63 08|BMW M6 E63 09|Audi S5 10|BMW M5 F10 12 blk
Audi RS6 C7 14 Dayt Grey|Vxhall Corsa 1.2LE Yell|Golf R 15|C63s Ed 1 Coupe|Porsche 911 991 Turbo S 14 Saph Blue|RS6 PE 16 Nogaro Blue|AMG GTS 16 Blue|M5 Comp White 18|Current: M5 Comp Snap Blue 19|Audi R8 V10+ Blk 18
Re: spark plugs
I don't have any noticeable misfires but after someone on here started a topic about their misfires I plugged my laptop in and found a real high number of misfires on one cylinder in particular (think it was cylinder 5). Most of the cylinders had a hundred or so but one cylinder was in the thousands.
Re: spark plugs
My old one used to do it... x 3 times over approx 15k miles.
EPC alight came on....then cleared.
Litchfield stage two.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Re: spark plugs
Could that be though thee engine switching from 8 cylinder to 4 cylinder mode and vice versa - mine is noticeable as it switches between the 2
2018 Brabus G63 Widestar
2015 RS6 - with Added Milltek
2015 RRS - utter sh1te
2010 X5 4.0D M Sport
2009 R8 V10 Manual
2004 Lambo Gallarado Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
1990 Dimma Cosworth H20 COS
2003 996 DMS Turbo
multiple 205's Dimmas
2009 R8 V10 Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
2003 996 DMS Turbo
- 1st Gear
Re: spark plugs
Could this amount of misfires on one cylinder cause it to fail ??? I'm sure you know why I ask the questionMikeFish wrote: ↑Sat Aug 12, 2017 11:13 pmI don't have any noticeable misfires but after someone on here started a topic about their misfires I plugged my laptop in and found a real high number of misfires on one cylinder in particular (think it was cylinder 5). Most of the cylinders had a hundred or so but one cylinder was in the thousands.
Re: spark plugs
Yes, this is the reason why you will see thousands of 'misfires' in the counters.
The only time you need to worry about an engine misfire is when you see the EML flicker. At that point, don't let it flicker again (stay off boost) and immediately check your plugs.
MY16 Audi RS6
Re: spark plugs
The plugs are not that accessible. There is quite a lot of gubbins to be taken off in order to access them - certainly on the O/s.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Re: spark plugs
Does anyone know what plugs come standard on the c7?
Sent from my SM-G955F using Tapatalk
Re: spark plugs
All C7 4.0TT (S/RS) these days should come with the latest version: 06K905601M
Wasn't aware of the PE having different sparks compaired the normal RS/S?
Recently replaced my spark plugs on my 4.0TT, was bit a work due to coolant reservoir and cable boom just over the coils/sparks, but it is doable
I had/still have some misfires, especially on cylinder 1 & 6. New spark plugs and changing coils places kinda ruled out this was the issue
Made my tuner remove COD aswell, much more 'relaxed' engine (stage 2 + aftermarket exhaust/catless), it didn't however reduced the misfires....
Re: spark plugs
Thanks for the reply.dasquade wrote:All C7 4.0TT (S/RS) these days should come with the latest version: 06K905601M
Recently replaced my spark plugs on my 4.0TT, was bit a work due to coolant reservoir and cable boom just over the coils/sparks, but it is doable.
I had/still have some misfires, especially on cylinder 1 & 6. New spark plugs and changing coils places kinda ruled out this was the issue.
When you changed your plugs, did you replace them with the same original stock plugs again or did you change the brand/brand?
Im running a stage 2, Decat, akrapovic, downpipes etc.. And wondering if it's beneficial to upgrade the plugs also?
Re: spark plugs
MRC change the plugs (for a different brand) when they do a stage 2.
Re: spark plugs
I have S6 (2013), previous owner had sparkplugs changed 20.000km ago but it where still the 'G' revisions (irrilavant for the RS models as they never came with those). Currently stage 2, so swapped to the 'M' OEM (NGK) spark plugs. The OEM plugs should be more then enough, i suppose MRC replaces them with the 'race' NGK ones. From what i read, proper plug gapping is more important (and should eliminate a lot of misfires).
@jipettersen: do you happen to have a 'software' number of that update? Again not for my (as this is a specific update for the RS, known issue with cilinder 5)....
COD indeed gives some 'odd/powercuts/stutters' especially on tuned and aftermarket exhausts. I recently got it deactivated aswell and a pleasure now
(and hopefully one expensive maintance/failure safer: motormounts!).
Re: spark plugs
These are the plugs recommended for a stage 2:dasquade wrote:I have S6 (2013), previous owner had sparkplugs changed 20.000km ago but it where still the 'G' revisions (irrilavant for the RS models as they never came with those). Currently stage 2, so swapped to the 'M' OEM (NGK) spark plugs. The OEM plugs should be more then enough, i suppose MRC replaces them with the 'race' NGK ones. From what i read, proper plug gapping is more important (and should eliminate a lot of misfires).
COD indeed gives some 'odd/powercuts/stutters' especially on tuned and aftermarket exhausts. I recently got it deactivated aswell and a pleasure now(and hopefully one expensive maintance/failure safer: motormounts!).
https://www.ngk.com/product.aspx?zpid=10135
Do you know ow what the recommended gap is?
Users browsing this forum: Google Adsense [Bot] and 116 guests
