As per the title and picture.
I have one plate for same. If you're thinking to do the mod, then save some money. I think if I recall they are over £30 each from TPS
And if I remember correctly they are from a C7 RS6
£15 delivered
Genuine Audi RS rear brake plate for B7 and B8
Re: Genuine Audi RS rear brake plate for B7 and B8
Does it include the fixing clips? You can't buy the clips separately from audi.
I'll have a look. Just digging up all my spare parts. Do you know what they look like?
Annoyed can't find them. Guess I'll use it as a key ring then. Lol
Pretty sure for retro fitting them on a b7 their are no clips or fixings, its a hole drilled into the caliper & glued/resined on.
RS4 B7
MRC stage2 436ps-487nm
Revolution intake, custom CAF, carbon clean, deflaped manifold, JHM manifold spacers, Forge oil cooler, Forge spacers, full de-cat, Scorpion cat back, Trup's LED's, 20' S5 wheels, KW V3's.
Launch control & flat shift
Cool. Thanks for the info. Still for sale then to all you B7 ownersTAB1S wrote:Pretty sure for retro fitting them on a b7 their are no clips or fixings, its a hole drilled into the caliper & glued/resined on.
Clips required to secure . Gluing in would not allow you to wind brake piston back to fit new pads .
