K&N Filter Element - any issues with oil?
Just ordered a K&N Filter Element (high flow) and the packing case
has quite alot of the anti-dust grease residue inside it.
I have heard of issues with these oils causing MAF or air sensors being gunked up.
Has anyone got any suggestions, experience or words of wisdom before I put it it? or should I just go for a factory element instead?
Cheers,
Cheers,
Re: K&N Filter Element - any issues with oil?
I can't comment on the K&N set up but I ran a MRC filter for most of the 6 years I owned my B7 with no issues at all
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Was it a pre oiled filter?
i Believe so its exactly the same as an IGT filter
Just had a look at IGT website they don't mention if there oil filled but when you click on the cleaning video it shows them re oiling the filter so it would look like the IGT and MRC filters ar pre oiled
Heres what I did:
1) Use K&N cleaner kit and washed / dried the new filter element
2) Lightly sprayed only the outer side with K&N oil spray
3) Cleaned the airbox and lubricated airbox flap so it returned easily on its own (was bit stiff before)
Lets see how it goes over time.
How did this turn out, any issues? Just ordered one for mine.Rodney007 wrote: ↑Wed Apr 12, 2017 5:21 amHeres what I did:
No issues at all, running fine
Leave it outside for a couple of days to dry out obviously somewhere dry
Rs4 b7 In avus silver with b14 Bilstein coilovers, centre resonator delete with x pipe and piggie cats gutted
Headlights detangoed trups led kit drl reverse and numberplate kit
Previous audi
rs6 c5 - mrc stage 2 remap-itg filters-forge dumpers-center decat with miltek kw coilovers- h and r
I call her the growler lol
Previous audi
or just buy a new one
This is the issue, the K&N filters come over oiled from factory, which in turn can effect the MAF sensor. So before installing i am cleaning my new one a couple of times and only adding a light coat of oil when its fully dry as suggested above.
Users browsing this forum: Google [Bot] and 87 guests
