Suspension arm bushes
5.0 V10 50v biturbo - 571 bhp
IanH755
Re: Suspension arm bushes
Post by IanH755 » Mon Jul 17, 2017 8:41 pm
MRC said they fit but the rubber compound was softer than OEM so I went with Lemforder in the end.
RossH14
Post by RossH14 » Sun Jul 23, 2017 3:37 pm
some advice - anyone have a trick' to get the rear bottom bush into place??
RS6 V10 Sepang Blue Avant
VW T5 4 motion
Lotus Exige GT3
IanH755
Post by IanH755 » Sun Jul 23, 2017 3:53 pm
A cleaned up hole with lots of lube usually gets me into the bottom bush :D
BamBam style jokes aside, if the hole is cleaned up and lubed slightly would a C-clamp have enough force/torque to press the bush?
Jim Haseltine
Post by Jim Haseltine » Mon Jul 24, 2017 8:38 am
A decent quality screw drive hose clip to compress the end of bush often helps. And as mentioned, lubrication.
RossH14
Post by RossH14 » Fri Jul 28, 2017 6:16 pm
yep - lots of soapy water - start at and angle then 'flip it in' worked.... now to get the rest of it all back together
VW T5 4 motion
Lotus Exige GT3
RossH14
Post by RossH14 » Sun Jul 30, 2017 10:53 pm
moving fwd - rear end assembled - now a break as i'm off sailing (Fastnet race), before sorting front
VW T5 4 motion
Lotus Exige GT3
Jim Haseltine
Post by Jim Haseltine » Mon Jul 31, 2017 12:25 pm
I'm really sorry but to me that combination of colours makes it look like you've fitted a kit from the Early Learning Centre.
RossH14
Post by RossH14 » Tue Aug 01, 2017 7:46 pm
yep - i am that big a child, as they say our toys just get more expensive :-)
VW T5 4 motion
Lotus Exige GT3
RossH14
Post by RossH14 » Tue Aug 22, 2017 1:28 pm
the ELC suspension is now complete
- having the alignment checked. but car feels much more taught.
DIY fitting is not for the faint hearted but IMHO a definite improvement over the rubber bushes
VW T5 4 motion
Lotus Exige GT3
IanH755
Post by IanH755 » Tue Aug 22, 2017 4:23 pm
Congrats dude, thats a lot of work you've done!
P300
Post by P300 » Sat Sep 02, 2017 7:27 am
I wish I had the facility to do all that at my place - that's a big old job! I'm still waiting to get time to get the ARB's on. Good work.
Erwan35
Post by Erwan35 » Tue May 15, 2018 6:52 pm
Guys i need help please. I need to change tie rods outer left and right. Any suggestions? It is not easyyyy. Im all the way in malaysia. As long as its affordable, dont really mind the oe quality. Cant even do alignment due to jammed nut. Please help
RS6 C6 SEDAN RHD VS_PERFORMANCE STAGE 1.5, 2ND CAT DELETE, MILTEK CATBACK, BMC DROP IN FILTERS. :blackrs4:
Erwan35
Post by Erwan35 » Tue May 15, 2018 7:05 pm
IanH755 wrote:
Mon Dec 21, 2015 11:34 am
Just bought a full front Meyle HD kit from eBay for around £330.
There are two bits which are supposed to be RS6 specific (track-rod ends and rear lower arm) however the two Meyle replacement parts in the kit are NOT RS6 specific and you can't buy the specific parts from Meyle as they don't stock them.
Just to take the mick, Audi want over £400 for the two track-rods and 2 rear lower arms and the whole "kit" would be about £1300 vs Meyles £330!
So did it work? The tie rods fit good?
IanH755
Post by IanH755 » Sat May 19, 2018 8:01 pm
IIRC I bought the Audi (lemforder OEM) parts as I believe (maybe wrong) that although the Meyle parts do fit the rubber used is of a lesser strength/rating compared to the Audi parts, which would make sense as those Meyle parts are the same number for A6 to RS6.
However that was over 2 and half years ago so I've no idea what the kit currently has or the spec of the materials in it.
Erwan35
Post by Erwan35 » Sat Jun 02, 2018 10:00 pm
Ok do u have a link for it so i can just buy it now please?
I dont mind if its not as good as oem but as long as it fits then its superb
