Oil usage
RSQ
Oil usage
Post by RSQ » Fri Jul 07, 2017 12:55 pm
So I am 7,000 miles in.
Oil check always says fine. Not a drop used. Really?
Broken sensor or normal?
RS4 B8 chugged a litre every 1,000 miles. :?:
Current Audis: Audi RS6 PE, Audi RS3 Sportback
Ex-Audis: RS4 B8, RS6 C6, A6 2.7Q, A4 2.8Q
gilford
Re: Oil usage
Post by gilford » Fri Jul 07, 2017 1:09 pm
Mine doesn't use any oil either :jump_clap:
Current - 2017 Nardo RS5 8)
wildbore
Re: Oil usage
Post by wildbore » Fri Jul 07, 2017 4:12 pm
No change at all in oil level from new to the 18,000 service. No change in the 10000 miles since, either.
harrier
Re: Oil usage
Post by harrier » Fri Jul 07, 2017 7:26 pm
One - 1.5L, if that, in 9.5K - loving it. Not the RS$ SC's 1L every 1,000 miles (gets expensive, if nothing else).
Audi quotes engine oil capacity 8.3L. After 8L of fresh oil the MMI showed it completely full ( would have preferred a dip stick), so it may be that Audi supply the car with 8.3L and that therefore at least 0.3L needs to be consumed before the MMI shows any oil useage. Anyone else found this when doing an oil change?
RS6 PE DMS, Daytona, Pano., 21" 5-V-Spoke Tit.Alloys, C/Ceramics, Dynamic Pack +, Parking Pack Adv., Assist. Pack, TV (MMI only), Road Angel (essential) + Python, A. Connect & Phone Box + S/phone Interface, Head-up Display and Night Vision Assist., RS6 Proj. Puddle Lights, Clear 3M Wrap.
Mini Cooper S ("hot"Chili) 265BHP; VW Fox 59BHP; Citroen C1 68BHP!!
RS4 (B7) w. TTS S/C, C/Ceramics - sold
Audi TT Coupe won at model launch, for 3 months, from Audi UK !
wildbore
Re: Oil usage
Post by wildbore » Sat Jul 08, 2017 9:41 am
My car came from the factory with the MMI level display halfway between empty and full, so I don't think any was used at all.
Tadass910
Re: Oil usage
Post by Tadass910 » Fri Aug 18, 2017 2:51 pm
That's actually not normal at all, I just drove 2000 km and my mmi oil level dropped, maybe your sensors are broken
brab
Re: Oil usage
Post by brab » Fri Aug 18, 2017 6:50 pm
When my car was delivered it was filled to the max...now 23,000km later is at 40-45%.
I did have 3-4 times 120mph-150mph sessions that lasted for about 20-30 minutes each (on Autobahn) and I generally drive about 100mph (car used only for outside of the city), as here in Croatia cops tolerate 155km/h without fines.
Markp
Re: Oil usage
Post by Markp » Fri Aug 18, 2017 8:59 pm
Normal for me too. No useage in 22000 miles (except changes at services). And sensor fine.
Kirky
Re: Oil usage
Post by Kirky » Fri Aug 18, 2017 10:28 pm
My car hardly used any oil for the first 12,000 oil change. I'm 20,000 now and about the 70% mark so overall very little oil usage.
Tadass910
Re: Oil usage
Post by Tadass910 » Sun Aug 20, 2017 10:35 pm
Maybe you drive like pensioner mate:) car uses oil and normally oil level drops when you really using car:)
That's very normal usage, if you drive and use car normally it eats oil, for example I have 82.000 km on a clock and car eats oil normally, each year I change oil, doing 15.000 km per year
