new rs4 with problems , help please
white.akita
Re: new rs4 with problems , help please
Post by white.akita » Fri Jul 07, 2017 4:20 pm
Anyone now know what to do with this information now it's plugged into VCDS ?Image
Sent from my SM-G935F using Tapatalk
rs user
Post by rs user » Fri Jul 07, 2017 4:45 pm
the readiness/incpomplete is probably because you have just re-set fault codes etc
white.akita
Post by white.akita » Fri Jul 07, 2017 4:48 pm
It is showing incomplete because it would not complete the test.
When the failed components were being tested they were constantly flicking between the on and off position regardless of how long I left it for.
white.akita
Post by white.akita » Fri Jul 07, 2017 4:56 pm
This voltage supply relay test is failing too constantly flicking on and off and the test will not complete.
Does this mean the relay is broken ? Where is the relay ?Image
white.akita
Post by white.akita » Fri Jul 07, 2017 5:02 pm
Intake manifold flap tests for both show it constantly flicking from 0% to 96.6%, test shows as failed.
white.akita
Post by white.akita » Fri Jul 07, 2017 5:07 pm
Evan constantly flicking on and off, test failedImage
white.akita
Post by white.akita » Fri Jul 07, 2017 5:08 pm
Same with secondary air pump, test failedImage
white.akita
Post by white.akita » Fri Jul 07, 2017 5:10 pm
FailedImage
white.akita
Post by white.akita » Fri Jul 07, 2017 5:11 pm
Circuit for brake vacuum pump PASSED
white.akita
Post by white.akita » Fri Jul 07, 2017 5:13 pm
Anyone have any clues at to what the fault may be?Image
rs user
Post by rs user » Fri Jul 07, 2017 5:46 pm
voltage supply relays are under the scuttle in a box beside engine ecu
there are 2x 70a relays and a little 393 labelled one
the first big relay[furthest away from the 393 ] gives engine comms faults etc if faulty
there are also several fuses under there
my first relay gave issues -a non start though[turned over but no start] and flagged up multiple engine comms faults
but-some vag cars show the cat signals incomplete after codes being cleared untill after a lot of driving
with cats removes or messed with you may have spacers or had the signal mapped out/ignored
white.akita
Post by white.akita » Fri Jul 07, 2017 5:55 pm
thanks very much arthur, i think i will test the relays tomorrow and replace if any are faulty. im hoping there is a faulty relay.
it would make some sense to me if it was a relay at fault because of how many tests failed, basically everything that has got to do with the vacuum system has failed.
marc1
Post by marc1 » Fri Jul 07, 2017 6:10 pm
white.akita wrote:
Thu Jul 06, 2017 11:49 am
That's true I bought a rs4 with problems and would like to fix them myself like I have done with over a hundred other cars with help from forums.
I don't need anyone to tell me that it's best to take it to a garage and let them fix it.
I have tried to get codes with VCDS life but it won't connect to the engine controller.
I have a aquantence coming tomorrow to give it a full VCDS scan.
I will post the results and hopefully then someone can offer some help.
Over 100 other cars? Are you buying them knackered, fixing them and selling them then?
white.akita
Post by white.akita » Fri Jul 07, 2017 6:16 pm
when the relay is being tested i can hear it constantly flicking between on and off every second, is it supposed to do this ?
white.akita
Post by white.akita » Fri Jul 07, 2017 6:37 pm
here is a video of the test, any help with this will be great
https://www.youtube.com/watch?v=XoJgc1KlAGM
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 283 guests
