new rs4 with problems , help please
white.akita
Post by white.akita » Tue Jul 04, 2017 9:09 pm
hi, just bought a rs4 today with some faults which im trying to fix.
i have edc light on and fault codes 08196,p0492,p2005,p2004.
the car seems low on power to me.
the only modification to the car is that the cats have been removed.
after a lot of searching it seems possible i have a vacuum leak.
any help on this would be fantastic
rs4pat
Re: new rs4 with problems , help please
Post by rs4pat » Tue Jul 04, 2017 10:12 pm
if the car has the cats removed it needs them mapped out too that should sort it
jonytek
Post by jonytek » Tue Jul 04, 2017 10:17 pm
Can you post the full VCDS output?
BUILD THREAD
IG: @bad_rs_4
white.akita
Post by white.akita » Tue Jul 04, 2017 10:21 pm
I don't have VCDS nor would I know how to put it on here.
Sent from my SM-G935F using Tapatalk
Jon_J
Post by Jon_J » Tue Jul 04, 2017 10:34 pm
white.akita wrote:I don't have VCDS nor would I know how to put it on here.
Then that could be a problem!
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
jonytek
Post by jonytek » Tue Jul 04, 2017 11:06 pm
Not sure people will be able to help with just error codes. Where did you get them from anyway?
I'd recommend booking the car into mrc for a health check. It only cost £150 from memory, they'll get it on the dyno, run full diagnostics and let you know of any issues.
Also pat is correct if the cats have been removed/gutted then they need to be mapped out otherwise the car will throw an error. This is quite possibly the issue which is no biggy. If the issue is serious the car will go into limp mode.
BUILD THREAD
IG: @bad_rs_4
white.akita
Post by white.akita » Tue Jul 04, 2017 11:20 pm
The owner has just said he removed the middle cats and they don't need mapping out.
He also said he had it done over 3 year ago and these faults only came up a couple of month ago.
white.akita
Post by white.akita » Tue Jul 04, 2017 11:26 pm
I thought he had removed all the cats.
white.akita
Post by white.akita » Wed Jul 05, 2017 12:26 am
Im reading that it could be the non return valve under the manifold, is there a reason if it is that at fault i cant just fit a one way non return valve inline with the vacuum tube that comes out from under the manifold ? that way i wont need to remove the manifold.
dougle_turbo
Post by dougle_turbo » Wed Jul 05, 2017 6:45 am
Sounds like he just removed the central resonators in the exhaust, not any of the cats. Also even it it were if the faults only came up a few months ago they are probably unrelated.
Without having a diagnostics scan done on the car, you will find it difficult to solve the problem. As Jony asked, where did you get the fault codes you mention in the original post?
p.s FON and rule number 1
2010 987 Cayman S.
Clio 172 Cup track car "Nicole" aka NV2 Sold
Clio 172 Cup track car "Nicole" aka NV1 - R.I.P
2007 Phantom black RS4 avant - with added ceramics. Sold
2006 Phantom black RS4 saloon. Sold
1990 Black Audi S2 (3B) - full engine rebuild. Sold
1981 Black Porsche 924 Turbo, rescued from under a tree and restored. Sold
rs user
Post by rs user » Wed Jul 05, 2017 8:50 am
sounds like stuck flaps-either due to vacuum or simply gummed up by the codes
remove inlet check /fix same
then deal with cats-but probably not an issue once you deal with the main probs
i would buy a VCDS cable tbh-worth their weight in gold
was it the blue one you bought -off flea bay...? seen one advertised reasonably priced with those codes mentioned
jonytek
Post by jonytek » Wed Jul 05, 2017 9:24 am
Did you buy the car with the light on?
BUILD THREAD
IG: @bad_rs_4
white.akita
Post by white.akita » Wed Jul 05, 2017 10:09 am
Yes bought car as is, I got the codes from my laurel scanner.
Looked under the car today and there is no pipes going to the exhaust at all, they have been removed.
Also there is zero vacuum, left running for 5 mins and if I pull a vacuum pipe there is no hiss, when running there is no vacuum whatsoever with my finger over the hole.
white.akita
Post by white.akita » Wed Jul 05, 2017 10:12 am
Where should I start looking if I have no vacuum whatsoever ?
norman1979
Post by norman1979 » Wed Jul 05, 2017 10:20 am
Where abouts are you based? If your local maybe somebody can help you with Vag Com
