Re: 12 Advanced measuring values via VagCom too see if engine runnig properly?
I'm guessing the pub is shut around your way?
Can we see what your Bank 1 and 2, sensor 1 and 2 are doing at idle when hot... A little video would be good so we can compare... Say idle at temperature for 2 mins, then hold at 3k revs for 30 secs, then idle for a min... That way we can see what your fuel trims are doing... Obviously 1 set of values will be in engine, and the other in engine 2...
Re: Can anyone tell me whats going on here when i logged my B7 RS4?
Looks like it is what it says it is... Defective knock sensor which is pulling your timing in... Can you do the lambdas at idle as I mentioned so i can see your fuel trims...
