Headlight bulbs
Headlight bulbs
Jumped in car this morning and was greeted by that dreaded beep.... main headlight bulb has gone
Audi have quoted me just shy of £600 to change the two..
What have other people done on here? Used different bulbs that the ones Audi supply?
Previously big turbo'd mk4 golf, big turbo'd Audi A3 Quattro
Currently remapped vw caddy
& 2009 rs4 saloon, TTS supercharged, mrc mapped, miltek catback, kwv3, h&r arbs, gutted precats, ceramic brakes 610bhp
Re: Headlight bulbs
Contact trups on here, he runs a company called em tuning which handles all bulbs, led kit etc. He'll be able to sort you out for much less than that. Good guy and people are very happy with his products.
Re: Headlight bulbs
Perfect answer. Thanks
Re: Headlight bulbs
You need D1S Bulbs, make sure you go with a decent make like philips or Osram and you will be fine! - Bumper off job to change the bulbs out
Re: Headlight bulbs
I did look under bonnet this morning and thought it looked a pig of a job.
I'll source some bulbs, pick and dry day and do it myself. Can't believe Audi want 600 supply and fit
Re: Headlight bulbs
Its not that hard once you have done it once... Good DIY on here if you have a quick search...
Re: Headlight bulbs
I just bought some...philips..£120 delivered..
Was a right nightmare to change...bumper off..light removal took ages..as the holes did not line up to loosen the screws...
Got my car back together finally...after 5 days. Needed a new bracket as the old nut snapped in it.. and a new light as it broke when putting the new bulb in..so be very gental...
Now have a light warning...been told Vagcom will sort this...so fingers crossed...
Good luck
Sent from my SM-G925F using Tapatalk
Good luck
Re: Headlight bulbs
Yup...i would not want to do that again...loltransitman wrote:Its not that hard once you have done it once... Good DIY on here if you have a quick search...
Re: Headlight bulbs
Result, found this site, seems like alright prices
Loads cheaper than what I was quoted this morning
https://www.powerbulbs.com/store/catego ... itting/d1s
Re: Headlight bulbs
I got the Philips gen 2 for £55 each... I will see if I can find the link
Re: Headlight bulbs
Thanks mate
So it says main left headlight bulb has gone on dashboard, but the running light on that side has stopped too, does it run off the main headlight bulb? Haven't got car with me at mo so can't check
Re: Headlight bulbs
D3s or d1s
whats the difference? One online Shop told me I need d3s?
Re: Headlight bulbs
Rs4 xenon's are D1s - I think this is the fitment type..
