I Actually covered mine in underseal and then covered it with some shaped thin steel i had laying around my unit, so it bascially acts as a "water shield"stevo55 wrote:Nice pipesdiscostu49 wrote:Funny you say that just wiped a little of my lines with a bit of kitchen roll and they were covered in some oily grease ...bear in mind my pipes have been replaced. What's strange is that a wee sleaved wire has nothing on it in terms of the oily residue pic belowmine look nothing like that...wondering if I should just coat them in grease and hope for the best of would that just be pointless? Audi gave them a clean bill of health and looking back at my photo it looks like a past of the pipes is corroded the rest is the metal clamp.
Corroded water coolant lines
Re: Corroded water coolant lines
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten
2017 Mercedes E63S W213 1033/1400nm
2013 Mercedes E63S W212 740/1200nm
2010 Nissan GT-R SVM 680R
2010 RS6 C6 Avant Stage 2 730/1088nm
Thats a good idea I have just had the coolant lines replaced on mine. Thankfully everything else was ok!TomRS wrote: ↑Fri Jul 22, 2016 10:13 amI Actually covered mine in underseal and then covered it with some shaped thin steel i had laying around my unit, so it bascially acts as a "water shield"stevo55 wrote:Nice pipesdiscostu49 wrote:Funny you say that just wiped a little of my lines with a bit of kitchen roll and they were covered in some oily grease ...bear in mind my pipes have been replaced. What's strange is that a wee sleaved wire has nothing on it in terms of the oily residue pic below
20160718_205902.jpgmine look nothing like that...wondering if I should just coat them in grease and hope for the best of would that just be pointless? Audi gave them a clean bill of health and looking back at my photo it looks like a past of the pipes is corroded the rest is the metal clamp.
Just had mine replaced! They were nasty, car's a 2008 on 46k miles. Basically every C6 needs this doing asap, its not an engine out job and Unit20 had in done in a morning! I regularly covered mine with white grease to protect them too
My new lines with the guys who do my powder coating for a layer of NATO spec epoxy, then I need to find the time to fit them.
Wow now THAT'S corrosion!! Mine (when I owned it) looked nothing like that. It really does seem that it's an inevitability and sooner or later they will need replacing. How much did Unit 20 charge?A20LEE wrote:Just had mine replaced! They were nasty, car's a 2008 on 46k miles. Basically every C6 needs this doing asap, its not and engine out job and Unit20 had in done in a morning! I regularly covered mine with white grease to protect them too
Current:
Former:
2016 R8 V10 Plus.
2019 E63s AMG 4Matic Estate.
2017 BMW M3 Competition Pack.
2015 A45 AMG.Overrated POS.
2016 C7 RS6 Panther black.
2006 BMW Z4M Roadster.
2004 Alpina Roadster.
1994 E34 M5 Saloon
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
Not gone through the bill as I had a few jobs done at the same time. Usually i give them a heads up on things I know needs doing and let them sort anything they spot on the day. The quote I had was parts + 4 hours labourstevo55 wrote: ↑Wed May 31, 2017 12:12 pmWow now THAT'S corrosion!! Mine (when I owned it) looked nothing like that. It really does seem that it's an inevitability and sooner or later they will need replacing. How much did Unit 20 charge?A20LEE wrote:Just had mine replaced! They were nasty, car's a 2008 on 46k miles. Basically every C6 needs this doing asap, its not and engine out job and Unit20 had in done in a morning! I regularly covered mine with white grease to protect them too
I think the fact that it's not an engine out job will be a relief to many...20-24 hours worth of labour cost plus parts adds up to quite the bill
Current:
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
Don't even tell me this!! I've pulled my engine to change these pipes and do the oil seal!!!!
S4 b5 340bhp
Rs4 b5 507bhp
Rs6 c6 project 800bhp
S3 stock daily work hack
Rs4 b5 507bhp
You would need to pull engine if you're replacing the whole pipe with a new OEM one but if you're just cutting out the corroded section from the existing pipe and replacing it with a custom section (which is what Unit20 etc do) then you don't.
I'm just painting my new ones with stone guard. Unit20 have fitted genuine parts not custom and there's no evidence of cutting and joining.
Im looking at an RS6 C6 and had a look through the wheel arch at the pipes and i can see some surface corrosion. Just wondering if treating it would save the pipes.
Having seen other pipes, there looks like there are couplers as if a section of the pipe has been replaced.
Does anyone know what colour the original coolant pipes are? I took my offside wheel off today to take a look at the condition, mine look black but in some of the photos the pipes look silver. All cleaned up nicely so I will perform annual checks. Car is on 31,000 miles but have seen some need changing around 40k so I was expecting to see a lot worse. Before and after pics below.
They're black. The OE coating is poor stuff to put things mildly - the guys who coated my new ones were less than impressed and also slightly surprised that the original pipes on my car had lasted as long as they did. Yours look amazingly good compared to most.
+1.
on Avg they are good for 8-10 years
. (e.g. in current terms, avg lifetime of a car's "model").
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
- H&R ARBs
slightly off the topic and out of curiosity, what's the part # for oil seal?
And is it a single seal that needs replacing or several?
Thanks!
Thanks!
- H&R ARBs
- H&R ARBs
Users browsing this forum: No registered users and 46 guests
