Intermittent Water Leak
RAS
Post by RAS » Sat May 13, 2017 10:46 pm
I have an intermittent water leak that appears to come out of the front bumper, in front of the front off side wheel.
Any suggestions as to where the water could be coming from?
Lukes3
Re: Intermittent Water Leak
Post by Lukes3 » Sat May 13, 2017 11:14 pm
Aux radiator,
One either side on the rs4. Commom thing.
Jon_J
Post by Jon_J » Sat May 13, 2017 11:23 pm
Head light washers? Does it leak when you wash the screen with the lights on?
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
RAS
Post by RAS » Sat May 13, 2017 11:27 pm
Thanks folks. It would be good if it was the headlight washers, however it's more than likely the aux radiator!
Jon_J
Post by Jon_J » Sun May 14, 2017 12:09 am
Intermittent? If it was aux rad why intermittent? Surely it would leak all the time?
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Fun and games
Post by Fun and games » Sun May 14, 2017 7:00 am
My Aux rad only leaked when it fancied it, some days it wouldnt leak, other days it used a fair amount.
RAS
Post by RAS » Sun May 14, 2017 8:46 am
There is occasionally steam emits from that corner of the car when I join a traffic queue, so fairly conclusive that it's an aux rad.
Not a clue why it would be intermittent.
nij
Post by nij » Sun May 14, 2017 11:58 am
The aux rads are only used as an additional cooling when coolant reach a higher temperature, otherwise the thermostatic valve stay close, so no water will circulate the aux rads.
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
RAS
Post by RAS » Sun May 14, 2017 1:04 pm
Makes sense. Thank-you.
RAS
Post by RAS » Fri May 19, 2017 9:57 am
What is it that'll be leaking. Is it the radiator or a hose that is connected to the radiator?
If it's the radiator, has anybody had any success using a radiator sealant, rather than replacing the radiator?
Starry
Post by Starry » Fri May 19, 2017 10:32 am
If it's the off side then bin it fit a cold air feed...
2006 RS4
Phantom black
RAS
Post by RAS » Fri May 19, 2017 7:30 pm
It is the off side. Could you send me a link to see what this looks like please.
Starry
Post by Starry » Fri May 19, 2017 8:36 pm
My aux is working fine atm so I've not done it but its a very common mod. Just do a search mate.
2006 RS4
Phantom black
Starry
Post by Starry » Fri May 19, 2017 8:38 pm
2006 RS4
Phantom black
Fun and games
Post by Fun and games » Fri May 19, 2017 8:58 pm
My finished example instead of replacing with another aux rad
Users browsing this forum: Majestic-12 [Bot] and 136 guests
