4.2 Turbo???
scotty51
4.2 Turbo???
Post by scotty51 » Wed Sep 14, 2005 8:26 pm
I have just bought a S4 with a 4.2 engine but i,m after more power Has anyone come across a turbo conversion to make it have the power of the RS6 !!.The RS6 was approx £10000 more expensive for the same age car. :cry:
Scotty
RE: 4.2 Turbo???
Post by Scotty » Wed Sep 14, 2005 9:29 pm
If you want more power then check out AMD's website. They do a supercharger that takes it up to 600+ bhp.
It's only £24k!!
Mines stage 3 which is about all you can do without spending silly money. Even then it's not quite at 400bhp.
What do you want out of it? Also the RS6 may be £10k more but it's a bigger class of car as well.
B8 A4 Avant quattro
Honda CBR1100XX Super Blackbird
Suzuki GSXR1000 (Track bike)
B6 S4 (AMD Stage 3) - GONE
8N TT (APR/AMD/MTM) - GONE
Merlot
RE: 4.2 Turbo???
Post by Merlot » Thu Sep 15, 2005 10:46 am
It would have been cheaper to have bought the RS6.
Maserati GranTurismo GTS Auto, S3 Sportback, TT2 3.2 Roadster, Disco3 for the heavy stuff.
B6S4John
RE: 4.2 Turbo???
Post by B6S4John » Fri Sep 16, 2005 10:27 am
I feel the same, slight modifications are ok, but to get lots more you need to upgrade more than just the engine, so it's usually cheaper to just buy a faster car in the first place.
Last one dead's a sissy.
tartan_rob
RE: 4.2 Turbo???
Post by tartan_rob » Fri Sep 23, 2005 11:02 am
Surely though the RS6 engine must be a much cheaper conversion? The block is basically the same, change fuelling, wap some turbo's on, play with ECU, pipework etc and bobs your uncle. If you buy an RS6 engine you could even sell your old S4 engine and re-coup a pile of cash...?
2017 Kawasaki Z1000
2014 RS6
2014 S1
S2tuner
Trader (Expired)
RE: 4.2 Turbo???
Post by S2tuner » Fri Sep 23, 2005 12:28 pm
Problem is I'm not sure there is enough room in the S4's engine bay to fit an RS6 engine... I had thought about this a few months earlier but after looking under an S4's bonnet, it doesn't look very good IMHO.... a full RS6 engine swap would be good, not sure how the ECU will like a manual transmission but I'm sure it's not the most major issue with all this...
HTH,
Mihnea
JonnyX
RE: 4.2 Turbo???
Post by JonnyX » Fri Sep 23, 2005 1:14 pm
I am pretty sure there is no room. They had to completley re-work the way the cam pulleys and belts fit in order
to get the V8 into the engine bay.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
wombat
Re: RE: 4.2 Turbo???
Post by wombat » Sun Sep 25, 2005 3:51 pm
Tartan_Rob wrote:Surely though the RS6 engine must be a much cheaper conversion?
The RS6 4.2L V8 block is 54mm longer (front to back) than the S4 B6 engine - that's why you can't swap one for the other :-(
Darren
:blackrs4:
B6S4John
RE: Re: RE: 4.2 Turbo???
Post by B6S4John » Wed Oct 19, 2005 7:00 pm
The B6 S4 dos'nt have cam belts, it has chains on the back of the engine. Belive me I know
