Anyone running a cheap track car?
marc1
Re: Anyone running a cheap track car?
Post by marc1 » Sat Mar 25, 2017 10:40 am
Can recommend Federal RSR road legal track tyres too. :thumb:
1781cc
Post by 1781cc » Sat Mar 25, 2017 10:54 am
R32 Arbs a cheap upgrade and plentiful as the VW boys sell theirs on - I picked up an R32 ARB for £30 on fleabay!
FaisalJ
Post by FaisalJ » Sat Mar 25, 2017 11:20 am
Currently:
- Stage 1 map
- Ramair filter
- Decat (have the cat section too)
- Much of the interior in the bin (door cards still on, and dash/climate still operational (no radio)
- Safety devices half cage welded in
- Federal RSR tyres
- Grooved front discs, with carbotech XP10 pads
- DS2500 rear pads
- 40mm lowering springs (std shocks)
- Cobra Monaco buckets with 5 point harnesses
It drives like a luxury go kart! Stops surprisingly well, and I'm hoping with tighter handling will be good fun on track.
1781cc - Yep, thinking about ARB upgrades, cookbots/bushes, and then a good geometry setup.
I've seen mention of a front ARB delete as a handling mod!? Any info on this?
2007 RS4 B7 Avant
marc1
Post by marc1 » Sat Mar 25, 2017 11:57 am
Not sure about the front ARB delete TBH. There is always much debate on Quattro cars for just upgrading the rear. That's all great if it's a small increase, but if you're going full aftermarket, I'd be doing front and rear. I've done that on all my S/RS cars bar the B7 (added SS+ to keep it a comfy road car) and there is good reason the suspension manufacturers do a front and rear package. I'd also add coilovers so you can adjust and can corner weight it when you do the geo.
Pleased you've got the tyres, they are great bang for buck and perform well once up to temp.
1781cc
Post by 1781cc » Sat Mar 25, 2017 12:23 pm
MadMax runs without any arbs in his 430hp TT roadster, his is the most extreme of the track TTs out there. ARBs can be good upgrades if you havent gone the full motorsport hog. If you are running standard suspension with springs I wouldn't delete the ARB. If you are running Gax Golds or Meister's/KW V3s then its worth considering. Plenty of things to do before you even consider getting that stuff done.
I am running FK Coilovers at the moment but will probably be going custom second half of the year so these might be available cheap when I do
I would recommend:
- Remove all the interior bits you don't need (FREE)
- Trim down and delete all the crap under the bonnet (FREE - SAI, EVAP, N112, etc...)
- Remove all the sound deadening if you have any left (FREE)
- Kill the counterweight, towing eye and so on from the rear (FREE and saves about 34kg)
- Get an odyssey PC680 and relocate it (it'll save a chunk of weight over the front axle
- Remove heating, aircon, loom, pipes, etc (FREE)
- Oil Cooler (essential)
- Hunter 4 wheel alignment (best to get adjustable tie bars for this)
- Superpro polybush around is a good idea as well (or Powerflex, etc)
You will find us all on the TT Forum in the Track & Motorsport section, have a good read through all the build threads, some of us have done similar things, some a little out there but a good place to track and learn as you go. We also have a register for days booked and stuff like that. VT runs a track day meet at Snetterton every year as well.
We have a thread called Church of the Lightweight which has weights listed for parts removed, its a good guide to follow
Post by HYFR » Sat Mar 25, 2017 2:39 pm
1781cc wrote:R32 Arbs a cheap upgrade and plentiful as the VW boys sell theirs on - I picked up an R32 ARB for £30 on fleabay!
Bugger!
I blame Marc!!
Post by HYFR » Sat Mar 25, 2017 2:40 pm
I just got some r888's
marc1
Post by marc1 » Sat Mar 25, 2017 2:52 pm
Bugger!
I blame Marc!!
They're not as thick as the H&R bars. It's like putting the RS4 rear ARB on an s4. Makes a marked improvement, but still left wanting more.
1781cc
Post by 1781cc » Sat Mar 25, 2017 4:25 pm
Bugger!
I blame Marc!!
Agreed - however for £30 the saving in £££ means you can also polybush that axle while you are in there
Post by HYFR » Tue Apr 11, 2017 11:27 am
At the ring today at circuit days
The R888's rubbing on the arches on a slightly lowered car
The_Coat
Post by The_Coat » Tue Apr 11, 2017 11:39 am
HYFR wrote:Image
At the ring today at Circuit Days
I spotted that McLaren a couple of weeks ago at the Rayleigh Weir, guessed it was Nigel from the plate. Looked savage!!!
Pro
RS4 Avant - Misano Red
Post by HYFR » Tue Apr 11, 2017 3:43 pm
Turns out this was the source of my rubbing
ARB linkage came away !! ImageImageImage
Post by HYFR » Tue Apr 11, 2017 4:27 pm
GP track tourist session
1781cc
Post by 1781cc » Tue Apr 11, 2017 4:35 pm
I was a Blyton on Sunday, good crack - nothing broke on the car, performed solidly all day - need more power now though...
FaisalJ
Post by FaisalJ » Tue Apr 11, 2017 4:42 pm
Hope you got that sorted DK!
So I've got the first trackday booked in the Turbo Tin-can: 29/04 Bedford- Anyone around?
Car's going in to the garage next week for:
- R32 rear ARB (£25!)
- Haldex insert
- Cookbot bushes, and rear wishbone caster increase bushes
Also a couple of sensors throwing intermittent faults getting swapped over.
1781cc - thanks for the tip on the R32 ARB! Hopefully see you on track at some point
2007 RS4 B7 Avant
