hdpete wrote:How do you upload speed camera locations as POI?
Oh God...... There's a whole massive thread about it but.......
Go to pocketgps site and download the Garmin style POI's. How to on the site.
You then upload the .csv or compatible files through myAudi in the audi connect section. Click on "Add personal POI". When you do this you add a specific image to each type of camera. This is the .bmp file or whatever the picture file designation is.
Now, you have to have java updated and installed for the next bit!!
Once you've added the POI's to the Individual Special Destinations in myAudi you then click the download button. This will download a .jnlp file. Bear in mind I'm on mac so might vary for widows.
Right click and select open with java the .jnlp file. It's like unzipping it and converting to files the mmi recognises. The java runs an audi converter tool where you need to log into again.
You are then left with a POI file where you chose to download it to. Format a 32gb or bigger sd card/USB stick and copy the POI folder over.
Goto car and select Set Up MMI. Scroll down to system update. The relevant SD1 or SD2 or USB should be highlighted. Select it and choose to update. The camera locations will be in your special destinations under Navigation Destinations.
I found it a bit temperamental....not always recognising the card but got there in the end.
When not walking on water I fly through the air with the greatest of ease.
