2003 AUDI RS6 QUATTRO, C5, 605 BHP Stage 3 Spec with MRC TUNING, GEARBOX FAULT
Before you read the information about the AUDI RS6, I've have just spend in the last 8months £2,000 sorting everything out on the car. ABS control module, Lamba Sensors, Suspension arms replaced which ones needed replacing and much more.
I haven't even drove the car for 8months, when it was finally ready to come out of the garage they phoned me and said there was a issue with Gearbox and it was driving but not changing gears properly etc.
The Garage then sent the Audi RS6 to a Gearbox specialist which then strip the Gearbox down and said the casing was smashed inside and wasn't worth repairing the gearbox then said i need to get another one and they could swap certain parts over from this gearbox. So now it is up for sale with a Gearbox fault.
i have spent thousands on this car but it has come to a point where i can't spend no more and it must go.
any enquires about the car please call me 07783177420
For sale is my pride and joy, No money has been spared on this Audi Rs6
Stage 3 engine spec with MRC
The gearbox rebuild was handled by a ZF UK authorised partner, Sussex Auto Transmissions.
The upgraded torque converter was built up at A.C.E. in the USA and featured a standard stall speed but rated to handle 750ft lbs.
The spare valve body was sent to 517 Trans in the USA and they rebuilt the VB to provide increased line pressure and reduced the operating tolerances for quicker shifting etc. To have solid transmission for the car
After the car completed a run-in with the new manifolds and turbos, it was tuned by MRC and made 605PS 846Nm. The car has covered 35,000 miles since the upgrades and gearbox rebuild, the trans fluid, filter and pickup tray have been changed 3 times during this period without any noticeable swarf or fluid discolouration.
The specs:
Black C5 RS6 saloon
Silver leather and silver alcantara headlining
Alu interior trims
RNS-D with a 2007 disc
Tilt and Slide sunroof (NOT SOLAR)
The modifications:
Bilstein B16 PPS9s
C6 RS6 390mm cross-drilled brake discs
Phaeton brake ducts
C6 RS6 6pot callipers
Braided lines
Hotchkis ARBs
MRC filters
Custom 70/60mm intakes
Wagner intercoolers and hoses (retaining OEM fog lights)
Stage 3 hybrid turbos
Custom tubular manifolds
Bosh 044 HPFP
Milltek ‘race’ downpipes (currently with an OEM CATback which sounds surprisingly awesome)
Plus spec hot weather radiators
TCU map with raised rev limit and lower RPM TC lock up
Stg III ECU map by Mihnea Cotet
A.C.E torque converter
517 Trans uprated valvebody
The other bits:
Some interior trim buttons are a little worn but nothing major, leather is in top condition, always used liquid leather.
Cam belt done MRC 2012 at 105,000miles.
MOT due 31/01/2017.
6 owners.
MILEAGE 132,000
Date/mileage/work
26/04/04 13600 audi uk certified SERVICE 10k service
20/09/04 22446 audi uk certified SERVICE 20k service
21/12/05 42106 NOTTINGHAM SERVICE 40k service inc. plugs, air, pollen, oil filters, brake fluid and cambelt, relay and rollers
21/12/05 42106 NOTTINGHAM REPAIR replaced clips for airbag trim, replaced all tyre valves, replaced heated mirror glass for o/s
04/03/06 45722 NOTTINGHAM REPAIR replaced hazard swtich
16/05/06 48642 NOTTINGHAM REPAIR replaced n/s/f engine mounting and replaced pollen filter housing
26/05/06 48846 NOTTINGHAM REPAIR replace convenience unit
04/09/06 53569 NOTTINGHAM SERVICE 50k service
04/09/06 53569 NOTTINGHAM REPAIR replaced handbrake cable holder, replaced engine cover grommets
29/09/06 53573 MOT MOT MOT
08/11/06 57828 NOTTINGHAM REPAIR replaced remote, rebleed hydraulic system
26/02/07 62302 NOTTINGHAM SERVICE 60k service inc. spark plugs, pollen and oil filter
26/02/07 62302 NOTTINGHAM REPAIR replaced rear bumper bracket
02/04/07 63333 NOTTINGHAM REPAIR full DRC replacement
12/09/07 68594 NOTTINGHAM REPAIR replaced vac pipe and replaced oil cooler pipe, replaced handbrake bracket
26/09/07 68600 audi uk WARRANTY warranty renewal
29/09/07 68892 MOT MOT MOT
09/10/07 69329 NOTTINGHAM REPAIR o/s/f outer driveshaft boot split replaced
17/10/07 69655 NOTTINGHAM REPAIR replaced thermostat
11/12/07 71815 NOTTINGHAM SERVICE 70k service inc brake fluid
25/07/08 79995 bexley REPAIR replaced front parking sensors, replaced aircon display unit, replaced aircon pressure switch
08/09/08 81043 audi uk WARRANTY warranty renewal
10/09/08 81484 MOT MOT
10/09/08 81484 bexley REPAIR full DRC replacement
10/09/08 81484 bexley REPAIR 2 x accumalator dash inserts, air con ecu, diff seals and 2 x power steering lines replaced
10/09/08 81484 bexley REPAIR new brake discs
10/09/08 81484 bexley SERVICE 80k service inc spark plugs, oil, pollen, fuel filter
01/05/09 8xxxx Aylesbury RePAIR DRC valve replacement, gearbox oil and strainer replacement
01/07/09 88000 Stafford SERVICE 10k service and Cambelt, relay roller change, wheels refurbed
01/07/09 87000 n/a REPAIR X 4 new tyres
01/08/09 90000 Chingford REPAIR replaced n/s/f cv joint
01/08/09 90000 Unit 20 REPAIR new brake discs and health check
22/09/09 91108 Chingford REPAIR replace rocker gasket covers, replace xenon starter, replace 4 shock absorbers
22/10/09 93512 Tamworth REPAIR replace alternator
22/10/09 93531 tamworth MOT MOT
16/02/10 96013 Camberly Audi 20k service. Replace power steering pump, crank seals and cambelt redone.
14/05/10 C6 discs and callipers
30/06/10 98000 PSS9, top mounts, control arms
05/07/10 98050 Rear discs, pads, ARBs, 4 wheels geo
15/12/11 106000 Uprated TC, recon’d gearbox, tubular manifolds, hybrid st3 turbos, Miltek race DPs, straight pipe CATback, 70/60mm intakes. Cambelt, thermosat, rollers, tensionsers, hot clime rads, plugs, HPFP Bosch 044, run in map.
02/02/12 107500 Wagners, stage 3 map, WM, 517 valvebody and gearbox service
Loads more MRC Tuning service details, I need to go through the mountain of paperwork.
70/60 custom intakes and tubular manifold.
£6,000 Welcome to Offers, Please Call me on 07783177420 as i am not on the forum that much, i can explain what happened with the gearbox etc.
Sorry forgotten how to put pictures put, if anyone wants pictures of the car please contact me. its been on this forum before and was previously owned by Bam Bam
The specs:
Black C5 RS6 saloon
Alu interior trims
The modifications:
Bilstein B16 PPS9s
Phaeton brake ducts
Braided lines
Hotchkis ARBs
MRC filters
Bosh 044 HPFP
The other bits:
MOT due 31/01/2017.
6 owners.
MILEAGE 132,000
Date/mileage/work
Re: 2003 AUDI RS6 QUATTRO, C5, 605 BHP Stage 3 Spec with MRC TUNING, GEARBOX FAULT
All that txt..thought there maybe a picture hidden in between..
Epic car, but if it didn't sell for £9k when fully working I think you'll struggle to get what you're asking now.
Sad to say, but think it might be better to break it.
Needs a cambelt service too.
it didn't sell and it wasn't fully working as it had the abs fault.
Wow! So how many miles has it done now? I thought I sold it at 130,000ish miles. So you've only spent £2k over the past 8 months? Seems a pretty cheap run for a C5.
GLWS.
GLWS.
Possible would Break the car if people are interested please call me
http://www.ebay.co.uk/itm/-/272596871407?
Ive done hardly no miles at all. its about 132 ish.
hahaha i hate c5 after owning this one.
UPDATE: The Gearbox on the car can be RECONDITION, just spoke to the Gearbox Specialist and he said its a common problem with these RS6, the drum in the middle of the Gearbox goes. there no other damage and has quoted me £3,000 to Recondition the Gearbox but i haven't got the money to do it.
The car is derivable but not ideal for long journey, it will need recovering away.
£4.5k?
Congrats on the sale. What you going for now?
Awesome, my old beast.
Present:...
Past:
Past:
Users browsing this forum: No registered users and 26 guests
