Revs not quite right
Hi all
When I put my foot down on the excelerater The revs go up as normal but then when I take my foot off the revs hangs there for couple seconds which doesn’t feel right, has anybody else had this problem,
Someone said it could be the clutch switch.
Advice much appreciated.
Re: Revs not quite right
We have the same problem - changed the switched no change changed the MAF sensor its fixed other things but not that
Switches sorry
It might be the PCV valve as it will have perished over the years, it's mounted under the carbon fibre RS engine cover.
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
Good suggestion
Great, i'll have a look at that.. Thank you
- Dantheman84
- 1st Gear
Yes best way to test pvc is remove you oil filler cap with engine
Running if it bogs done and almost cuts out your valve if definitely faulty hope this helps
RS4 kw v3 full miltek no cats
Intake spacer deflap stage 2 flat shift launch
Kawasaki ZX10R 197bhp
Thanks for that tip..
- Dantheman84
- 1st Gear
No worries I know this cuz mines has failed last week so in the process of stripping down and carrying out carbon clean too
Also I have ordered spaces for inlet manifold that's ment to
Make a difference too so we will see
Did you find out what was wrong ?
are you sure? read elsewhere on here that the rs4 b7 still does that with a new valve fitted? ....Dantheman84 wrote: ↑Tue Mar 21, 2017 9:56 pmYes best way to test pvc is remove you oil filler cap with engine
Based on my experience, yes it still bogs down some but far quicker recovery and although mine did not shut down engine when it failed/was replaced, it almost stalled. So before and after was still noticeable different, upon change.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 87 guests
