Charger build thread
J1TVV
Re: Charger build thread
Post by J1TVV » Sun Mar 05, 2017 9:49 pm
Luke, great progress! Thanks for doing the detailed updates!
Jit
2016 RS3 8V
2007 RS4 B7 Cabriolet Gone
Lukes3
Post by Lukes3 » Sun Mar 05, 2017 10:06 pm
Cheers mate, im trying to keep it interesting lol. :thumbs:
Lukes3
Post by Lukes3 » Sun Mar 12, 2017 7:45 pm
Right lads, update.
next was to sort the vac lines out, i forgot to take pictures of this. But all you do is "i think" is run the right hand side vac line that runs in front of the head to a T piece keep the one way valve in the line then take a feed off the supercharger and another feed off for a test point for when been mapped.
Also routed the oil in and out for the supercharger, these just feed near to the header tank for later on.
Next was to wire in the new air intake sensor, you wire this to the oem MAF sensor wiring. Next was to fit an seal the charge coolers in place and bolt the lid down.ImageImage
Once that was done i fitted the new fuel rail. To be honest this was a pain in the a** to get it all lined up basically it is all just so tight under there but i did it in the end. Image
Then it was time for the famous lid and the air intake pipe, this needed to be trimmed to fit nice but i think i took to much off so i may order an new one. The marks on the lid is from the bubble wrap Image
Next was to start on the pulleys, I done the alternator pulley as that was easy. The weight diffrence in this pulley is definitely noticeable as the old one is steel an the new tts one is aluminium, have not done the crank pulley yet as i need a 3 leg puller to get it off. Image
Also removed the SAI air pump as well beens that doesn't get used anymore. I removed the pipes aswell to the valves at the rear of the engine while doing that.
Dose any one know if the valves at the back of the engine need blocking off?
J1TVV
Post by J1TVV » Mon Mar 13, 2017 10:52 pm
Great woke Luke, Keep the updates coming! Looking forward to hearing what it's like.
Jit
2016 RS3 8V
rs4pat
Post by rs4pat » Sat Mar 18, 2017 3:08 am
good to see someone doing this them self keep up the good work luke . ps iv'e just put a radtec oil cooler on my car and all seems fine cost £400
Lukes3
Post by Lukes3 » Wed May 10, 2017 8:30 pm
Not up dated in a while, all up an running now, what a beast.
jonytek
Post by jonytek » Wed May 10, 2017 8:33 pm
Ah I'm jealous mate. Maybe next year. What was the final power reading from MRC?
BUILD THREAD
IG: @bad_rs_4
J1TVV
Post by J1TVV » Fri May 12, 2017 7:56 pm
Luke, can you give us your impression of the kit and how it drives now compared to before, some real world experience please.
Thanks in advance.
Jit.
Jit
2016 RS3 8V
Post by MikeFish » Fri May 12, 2017 8:05 pm
Yeah come on, more info!
Lukes3
Post by Lukes3 » Fri May 12, 2017 8:35 pm
Well it ran a 614ps at mrc had a couple of issues one been a injector fault even though i put 8 new ones in. :audibash: had a missfire at 7500 ish rpm but didnt do it every time. Also doug said the oem back boxes are restrictive so i will be changing them at some point,
But... driving home was brilliant i haven't drove the car because i have no licence due to the health issue earler in the year :thumbsdown: a mate drove it home for me but as a passanger it is a completely diffrent car. You think 3rd gear is good standard. Supercharged is somthing else.
jonytek
Post by jonytek » Fri May 12, 2017 8:52 pm
I remember him mentioning the back boxes when I enquired. With a new exhaust you should be up around 640?
BUILD THREAD
IG: @bad_rs_4
Lukes3
Post by Lukes3 » Sat May 13, 2017 8:37 am
Hopefully should be up around 630-640 soon as i get new back boxes doug said bring it back to see what its doing.
iconic78
Post by iconic78 » Sat May 13, 2017 2:23 pm
640 whp?
J130YCE
Post by J130YCE » Sat May 13, 2017 11:37 pm
Just had mine back last month after a health check and some bits and mine read at 620ps. It's manic on song, how the b7 should be
BMW M2 Comp
RS4 Supercharged
Current Abarth 500c Two tone Grey and Mint - a modified go-cart.
Current T5 180 bi-turbo - modified, Reimo pop top, ABT kit, Caravelle 7 seats, going on 'air' this summer
Gone RS4 B7 Avant MRC, MK5 R32, 205 GTI, Mk1 golfs... plus some other poor souls
Rw@@dy
Post by Rw@@dy » Sun May 14, 2017 7:24 am
Did you stay with oem clutch?
Return to “Readers' Rides”
