Intake Manifold Flap Drive Unit
RS4786
Post by RS4786 » Fri Mar 10, 2017 10:27 pm
Hi guys
Need some help please, keep getting code p2015/p2004 intake manifold flap bank 1 sensor sporadic implausible
was at unit 20 yesterday to get my drc sorted, martin took a look & said possibly need a new left flap drive unit will cost over 1k to supply/fit as they recommend carbon clean at the same time, new drive unit is around 399 :thumbsdown:
so i was wondering where can i buy flap drive unit from for reasonable price & is the only way to replace it is by removing manifold is there any other alternatives ? thanks :thumbs:
Re: Intake Manifold Flap Drive Unit
Post by MikeFish » Fri Mar 10, 2017 10:44 pm
Recommend doesn't mean you have too. I know it probably makes sense to do it while the manifold is off but is not essential. And aren't these the flaps you can remove?
Grandadg90
Post by Grandadg90 » Fri Mar 10, 2017 11:35 pm
Then you will most likely have to map it out. As the flap sensors will have to stay in place, but flaps can be removed.
Daytona Grey, Bilstein Coilovers, Pre-cat delete, Centre resonator delete, IM flaps/vains delete, Interior/Exterior LED kit, CAI, Black Optics.
Other car: Bread Van
Covkiller
Post by Covkiller » Sat Mar 11, 2017 9:28 am
I had play in the shaft that holds the flaps. I didn't want to replace it, but for the cost of a new manifold I had MRC remove the flaps and do a full carbon clean. +2 PS achieved too, happy days :jump_clap:
TAB1S
Post by TAB1S » Sat Mar 11, 2017 9:37 am
There's a manifold in the for sale section, buy that & do your own carbon clean.
RS4 B7
MRC stage2 436ps-487nm
Revolution intake, custom CAF, carbon clean, deflaped manifold, JHM manifold spacers, Forge oil cooler, Forge spacers, full de-cat, Scorpion cat back, Trup's LED's, 20' S5 wheels, KW V3's.
Launch control & flat shift :mrgreen:
jasonhudds
Post by jasonhudds » Sat Mar 11, 2017 5:26 pm
I may be wrong but I believe Awesome GTI centre Manchester have an upgraded Ali mechanism for the inlet manifold instead of the plastic , they had them advertised on eBay if this is the correct part ?
Users browsing this forum: Google Adsense [Bot] and 80 guests
