Front suspension arms - options?
Re: Front suspension arms - options?
Did you do the arms yourself?
If so, would you say they could be DIY'd on the drive with axle stands etc? Special tools, eg. ball joint splitter?
Ta
Mike
Ta
Mike
my mechanic and friend changed all the arms, i wouldnt recommend this type of work to be DIY other than if you really know what youre doing, either way, mechanic or not, you still have to get the car to a company that can adjust the steering.
Audi Power
Where did you get the Meyle parts from?
Daytona RS4 Avant - black optics/decat downpipes/H-pipe/KW springs - featured on the 2012 Audi stand at the Goodwood FoS
i ordered the complete suspension arms kit from kms on ebay, left spindle i found for bidding on ebay(brand new OEM) for very good price, right one i ordered fom my audi dealer.
Audi Power
How are you guys getting on with these kits, I guess time will tell.
What was the reason for changing the spindles optimus47?
RS4 B7
MRC stage2 436ps-487nm
Revolution intake, custom CAF, carbon clean, deflaped manifold, JHM manifold spacers, Forge oil cooler, Forge spacers, full de-cat, Scorpion cat back, Trup's LED's, 20' S5 wheels, KW V3's.
Launch control & flat shift
Any chance of a link bud im struggling to find them?Bladerider wrote: ↑Mon Feb 20, 2017 1:04 pmJust FYI,
I run Eibach Pro adjustable arms, they tend to only be listed as a B8 part but they fit fine and avoid the exact problem discussed above for 034 (which I run everywhere else) so you can adjust in situ.
Hope that helps.
RS4 B7
RS4 B7
- Bladerider
Lovely job thanks
Very pricey things for what they are really.
RS4 B7
Toe is what wears tires. Not camber. I have zero toe, max camber, max caster. Normal tire wear. The 034 are good. Not easy to adjust for sure. But I no longer daily drive the car. The one thing is that the rear arm rose joint does impact on the hub carrier. Mine bent so I filed the corner that impacts and all good.
Users browsing this forum: No registered users and 89 guests
