Bilstein b14 question
Starry
Post by Starry » Sat Feb 18, 2017 7:59 pm
I fitted mine a few weeks ago and have let them settle, so today i went to adjust them when i noticed the smaller coil was fully compressed when the car was not sat on the wheel and had no weight on it. Was this to do with anti roll bar as the other wheel was on the ground? was this because its only used to keep the main spiring in place if the car is jacked up or leaves the ground whilst driving?
2006 RS4
Phantom black
MRC Stage 2, Milltek non res, pre cat delete,
weekenny
Re: Bilstein b14 quetion
Post by weekenny » Sat Feb 18, 2017 8:39 pm
The helper spring is to keep the main spring located at full droop. On the B14 instructions the helper spring should go to the top. When I adjusted mine today the helper spring wasn't squashed like that as it's on the top.
Starry
Post by Starry » Sat Feb 18, 2017 8:53 pm
Ive seen them done both top and bottom, i went with bottom as it allowed the main spring to sit in the top mount rubber properly. The small spring has a flat coil and would not sit properly. Surely though, top or bottom it will compress the same as its a weaker spring.
2006 RS4
Phantom black
weekenny
Post by weekenny » Sat Feb 18, 2017 9:34 pm
I've attached a picture of mine. I wasn't sure about how it would seat but went with the instructions. The B16 it goes to the bottom.
Starry
Post by Starry » Sat Feb 18, 2017 10:09 pm
Has anyone else got a picture of these fitted or any advice on the position of the smaller spring?
2006 RS4
Phantom black
bazza138
Post by bazza138 » Sat Feb 18, 2017 11:21 pm
Interesting!! I be doing my soon
pule333
Post by pule333 » Sat Feb 18, 2017 11:46 pm
I have fitted mine at the bottom as it would not fit correctly at the top. I have spoken with bilstein regarding this and they said it makes no difference really where it is fitted because it will be compressed anyways at normal riding conditions. As long as the top spring fits correctly in to the cup.Image
RS4 B7 aka Vinnie
Starry
Post by Starry » Sun Feb 19, 2017 12:01 am
That was my thought, the thick spring sits properly in the top rubber mount. Cant work out why my helper springs are fully compressed whilst jacked up...
2006 RS4
Phantom black
pule333
Post by pule333 » Sun Feb 19, 2017 12:08 am
Yeah agree that's a bit wierd. Mine not like that when jacked up. Maybe your set very hight?? Image
RS4 B7 aka Vinnie
Starry
Post by Starry » Sun Feb 19, 2017 12:13 am
Im running pretty low so i don't think its that..
2006 RS4
Phantom black
pule333
Post by pule333 » Sun Feb 19, 2017 12:16 am
Same as me. Wierd..Image
RS4 B7 aka Vinnie
weekenny
Post by weekenny » Sun Feb 19, 2017 12:29 am
Looks about the same as mine. 660mm ground to arch (SS+ less 10mm).
Starry
Post by Starry » Sun Feb 19, 2017 12:36 am
I think mine was 640mm, then i raised it today by about 10mm, not had it on level ground to check the new hight yet. Cant think how it can compress without more weight pushing it down. Very strange.....
2006 RS4
Phantom black
Starry
Re: Bilstein b14 question
Post by Starry » Sun Feb 19, 2017 12:56 am
Just a though, i wonder if i was sent the saloon springs and not the ones for the avant and cabriolet as there are two spring ratings....
2006 RS4
Phantom black
weekenny
Post by weekenny » Sun Feb 19, 2017 1:00 am
What's the part number on your box?
Users browsing this forum: Cappencond, Majestic-12 [Bot] and 101 guests
