RS6 C6 front brake kit
Hi all,
Came across this big brake kit for the front of a C6 RS6. Maybe a good upgrade at a reasonable cost, 8 pot calipers, 405mm diameter floating discs, race brake pads and braided brake lines £1889 plus postage.
http://pbbrakes.com/audi-rs6-c6-08-11-f ... e-kit.html
Anyone tried this kit?
Just an idea for you c6 rs6 owners
Andy
Andy
- 1st Gear
Re: RS6 C6 front brake kit
Interesting, mine could definitely do with a bit more stopping power. I wonder what I'd get for my current OEM setup on eBay.
____________________________________________________
RS6 C6 MTM Map Engine & Gearbox STAGE2
I think the OEM kit from rs6 c6 fetches around a grand on eBay in good nickStudiowise wrote:Interesting, mine could definitely do with a bit more stopping power. I wonder what I'd get for my current OEM setup on eBay.
- 1st Gear
Thx AndyevoAndyevo wrote:I think the OEM kit from rs6 c6 fetches around a grand on eBay in good nickStudiowise wrote:Interesting, mine could definitely do with a bit more stopping power. I wonder what I'd get for my current OEM setup on eBay.
Well that's a bit of a no-brained then as I was liking to spend £800 on the brakes next time round so I could get this upgraded kit and then recoup a chunk of the outlay. Hmmm.
Your welcome, I can't tell you what this upgraded kit is like but I have used performance friction brake products on my evo's and they performed really wellStudiowise wrote:Thx AndyevoAndyevo wrote:I think the OEM kit from rs6 c6 fetches around a grand on eBay in good nickStudiowise wrote:Interesting, mine could definitely do with a bit more stopping power. I wonder what I'd get for my current OEM setup on eBay.
- 1st Gear
might do some digging around to see if anyone else has mentioned them on 'other' forumsAndyevo wrote:Your welcome, I can't tell you what this upgraded kit is like but I have used performance friction brake products on my evo's and they performed really wellStudiowise wrote:Thx AndyevoAndyevo wrote: I think the OEM kit from rs6 c6 fetches around a grand on eBay in good nick
If the decision is steels over ceramics I probably wouldn't look any further than these viewtopic.php?f=47&t=122027
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
Problem with these kits is that they don't produce vehicle specific piston sizes, so it's hit and miss whether the piston area will be compatible with your master cylinder. If the piston area is too large in relation to the master cylinder, you end up getting a mushy pedal, and have to pump the pedal before the brakes activate fully. I made this mistake a few years ago, buying one of these brings generic kits from a Taiwanese company. Look lovely, but don't work.
Companies like Brembo, AP and Stoptech produce specific kits for designed to work for a particular application, with matched piston sizes, so that the pedal travel is optimised.
Food for thought. Buy cheap, buy twice...
C6 RS6 Plus with a few sensible mods...
Before going with the AP Racing 420mm kit I also looked at these but couldn't find any decent "independent" reviews any later than mid-2013, just some very positive owners reviews. Their actual name is/was Phat Boy Brakes and they are made in the same factory as K-Sport brakes so are a cheaper clone of those.
In the end I chose AP-Racing for a number of reasons but my main one for AP vs PB Brakes as they're based in the UK so if there are any issues it's much easier to get things sorted, plus they're a "known" motorsport quality manufacturer with a massive R&D section so I knew everything would be built to a high quality, work at extremes and be durable.
In the end, once you've added £250 for 2 piece rotors (now upto £1800), £200 for shipping, £90 Duty and £400 VAT, it's £2500 for the kit which isn';t so cheap for a kit coming from Taiwan.
Truly an epic kit as Ian said the AP 410's lasted 10+ laps of croft circut without any fade whatsoever they really are a stunning kit for the money, reccommend a brake fluid upgrade to AP's RadiCal R4 fluid or RBF600 etc.
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten
2010 Nissan GT-R SVM 680R
i've just fitted teh AP kit (as per Tom) and looking fwd to giving them a work out
Ross
Ross
RS6 V10 Sepang Blue Avant
VW T5 4 motion
Lotus Exige GT3
VW T5 4 motion
Lotus Exige GT3
Make sure you give them a very good bedding in. Mine were a bit "meh!" until I got the AP DS25 pads hot enough to start gassing off (took about 8 70-10mph emergency stops) but once bedded, HOLY POOP!
Still happy with the RS6 Ian, i'll have to give you a buzz later on!
I'm available at work til 6 most days matey!
Users browsing this forum: No registered users and 70 guests
