Alternator time
mavada
Re: Alternator time
Post by mavada » Thu Jan 26, 2017 2:48 pm
Trying to get the old oilfilter out, noticed theres hardly Space to get it out/New one in....
Do i have to remove some parts? Probably need some girly hands to reach/get it out...
I think i need to loosen the swaybar. ..
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
simonpoulton
Re: Alternator time
Post by simonpoulton » Thu Jan 26, 2017 3:29 pm
Yeah found it really easy once the ARB was off
Past: R56 Mini Cooper S
mavada
Re: Alternator time
Post by mavada » Fri Jan 27, 2017 12:39 pm
Fitted oilfilter, not sure whats handtight, 20nm is shown on the outside of the filter.
I tightened it with a tool, probably overtightened....?
Same with the drain plug (with New gasket), i havent got elsa with me, so i dont have a clue whats the spec nm.
Yellow Koni's
Re: Alternator time
Post by Shoppinit » Fri Jan 27, 2017 12:54 pm
You should never tighten an oil filter with a tool. Hand tight is just as tight as you can do it by hand. That's probably around 20Nm.
It probably won't be a problem, just remember that when you come to change it next you might need a removal tool or to get medieval on it to get it loose.
mavada
Re: Alternator time
Post by mavada » Fri Jan 27, 2017 1:35 pm
What nm do i have to use to refit the drain plug?
I might do the sportec mod while its out, as you can see, it already has some nice vent holes in it....
Yellow Koni's
mavada
Re: Alternator time
Post by mavada » Sat Jan 28, 2017 6:51 pm
Took it for a spin to see if there are Any leaks, all fine.
Reinstalled the undertray.
Driving home after work, After some kms the engine light appeared.
Could this be because i started the car for some seconds without fuse 32 to prime oil?
Or because the battery was disconnected during the alt stuff, or oil (and oilcooler) refill related?
Its driving fine.
Yellow Koni's
Re: Alternator time
Post by Shoppinit » Sat Jan 28, 2017 10:17 pm
Oops. It was supposed to be fuse 29. Sorry. 29 doesn't give codes. Just clear the code with the Vagcom.
Re: Alternator time
Post by chunky79 » Sun Jan 29, 2017 8:13 am
Shoppinit wrote:Oops. It was supposed to be fuse 29. Sorry. 29 doesn't give codes. Just clear the code with the vagcom.
:shock: Shopp made a boo boo.
Good luck to the person who is removing your filter next time Mav if you tightened it with a tool!
Did you end up doing the Sportec mod too?
mavada
Re: Alternator time
Post by mavada » Sun Jan 29, 2017 9:01 am
No i had to use the 6 so had to hurry gettting it on the road again....
Will do it in the near future, its not that a big deal.
I Will clear the code, i think i could have removed fuse 29 and/or 32, both engine timing or ecu stuff i think.
No big deal. :D but unfortunately havent got Vagcom at hand.
Yellow Koni's
Re: Alternator time
Post by chunky79 » Sun Jan 29, 2017 9:53 am
I can send my Vagcom cable to you if you want Mav?
mavada
Re: Alternator time
Post by mavada » Mon Jan 30, 2017 9:37 pm
Hi Chunky,
Thanks for the effort, i Will check if one of my clone Vagcom is working.
Unless you are sick and tired of yours and want to get rid of it... :D
Yellow Koni's
Re: Alternator time
Post by chunky79 » Tue Jan 31, 2017 7:42 am
It's not for sale Mav, but you can borrow it.
mavada
Re: Alternator time
Post by mavada » Wed Feb 01, 2017 7:46 am
The enginelight disappeared yesterday before driving home from work. ...
Yellow Koni's
Re: Alternator time
Post by Shoppinit » Wed Feb 01, 2017 10:44 am
Most MIL faults will disappear after a certain time of not being present. The fault code will still be there, though, as intermittent. Would be interesting to know what it is.
/you might have loads because fuse 32 powers a sh1t load of things.
Mɐʇʇ
Re: Alternator time
Post by Mɐʇʇ » Wed Feb 01, 2017 10:29 pm
Yer, the brain is pretty good a getting on with it even after a shed load of errors. But Shopp's right - you really wanna do a reset.
Where are you - I assume the neanderthal land means north of luton? Or the Netherlands.
Users browsing this forum: rs4wagon and 64 guests
