Will fitting the RS5 20" Rotor really affects handling/ride?
Starry
Re: Will fitting the RS5 20" Rotor really affects handling/r
Post by Starry » Tue Jan 24, 2017 1:54 pm
ixi_ixi wrote:Spacers are illegal here unfortunately....
and I heard 3mm spacer (even hub centric ones) will likely to cause vibration as there is not much hub contact left. The beveled edge of the wheel face contact is not helping either.
Starry can you tell me more about your S3 setup? Cheers.
The aftermarket wheels I fitted to my S3 which was using RS3 custom brakes actually touched so I installed 3mm spacers and they were not visible without removing the wheel. They are so thin that the wheels still has loads of hub to sit on and should cause no problems.
2006 RS4
Phantom black
MRC Stage 2, Milltek non res, pre cat delete,
FaisalJ
Post by FaisalJ » Tue Jan 24, 2017 3:22 pm
Shaving a mm or 2 off the brake caliper might be the way to go then, if the fit really is that tight, spacers not an option and your planning to refurb anyway.
I ran wheels with what I recall as being 2 to 3mm clearance, including on track, without a problem
2007 RS4 B7 Avant
Post by MikeFish » Wed Jan 25, 2017 1:18 am
I've been running like this for 2 years with no problems.
ixi_ixi
Post by ixi_ixi » Wed Jan 25, 2017 4:14 am
MikeFish wrote:I've been running like this for 2 years with no problems.
Hi MikeFish, do you mean running no spacers with your RS5 Rotor?
B7 RS4 Cabriolet
Ported and deflap manifold, carbon fibre intake, piggies, MRC remap and heaps of preventive maintenance works lol
WTF its Arturo
Post by WTF its Arturo » Wed Jan 25, 2017 6:10 am
I run 255/30 on my RS5 rotors with 10mm spacers all around w/ ~2.1 deg camber. There is a massive difference from the way that my vehicle handles in comparison to the stock 19's with 275/30 Nitto NT05s with 10mm spacers. But that's largely due the tire selection/sizing. I'll use my stockers on the track, and even doing some spirited driving on the RS5 rotors i don't feel the same amount of grab + lots of rubbing with the rotors. I'm sure if I were using 275/30 with no spacers, it would be comparable.
RS5 rotors w/ 255/30
Stock w/ 275/30 w/ 10mm spacers
2007 Sprint Blue RS4 | JHM catted non-res full exhaust, tune, IMS, Solid SS trio kit | 034MS UCA, RSB, F/R SB end links, Diff spacer | OEM RS6 FBSW, S4 DTM CF splitter, Silver RS5 Rotors 20x9 +16 255/30 | KW V3 | Ziza everything | Apikol Diff mount
ixi_ixi
Post by ixi_ixi » Wed Jan 25, 2017 8:06 am
Thanks for the photo. That looks tight as well. I will be happy if I have 2-3mm clearance.
But mine is so tight with probably 0.5mm to 1mm clearance that really worries me :?
FaisalJ wrote:Shaving a mm or 2 off the brake caliper might be the way to go then, if the fit really is that tight, spacers not an option and your planning to refurb anyway.
B7 RS4 Cabriolet
ixi_ixi
Post by ixi_ixi » Wed Jan 25, 2017 8:10 am
WTF its Arturo, thanks for the feedback.
BTW, that's a very clean Sprint Blue, the silver Rotor looks amazing on your car :thumbs:
B7 RS4 Cabriolet
Post by MikeFish » Wed Jan 25, 2017 8:51 pm
Yes, I have RS5 Rotors with no spacers. As you say it is bloody tight, literally no clearance. But, mine has been like that for 2 years through hot and cold and never had an issue.
ixi_ixi
Post by ixi_ixi » Thu Jan 26, 2017 5:19 am
Great MikeFish, thanks for your feedback :thumbs:
B7 RS4 Cabriolet
Covkiller
Post by Covkiller » Fri Jan 27, 2017 1:01 pm
I run 4mm spacers with only a gnats bolx width between the calliper and S7 20" wheels for the last 3 years, done at least 15 laps around the Nurburgring and over 190MPH on the Autobahn with no issues whatsoever. People who says that normal car callipers expand when hot talk <beep>. My discs were so hot once that they had smoke coming off them when coming off the Nurburgring with no calliper wheel issue.
ixi_ixi
Post by ixi_ixi » Sat Jan 28, 2017 10:02 am
Good to know that mate.
For reference, roughly what is your brake/wheel clearance in mm?
B7 RS4 Cabriolet
Post by Ian_C » Sat Jan 28, 2017 10:59 am
Covkiller wrote:I run 4mm spacers with only a gnats bolx width between the calliper and S7 20" wheels for the last 3 years, done at least 15 laps around the Nurburgring and over 190MPH on the M69 with no issues whatsoever. People who says that normal car callipers expand when hot talk <beep>. My discs were so hot once that they had smoke coming off them when coming off the M45 into the A45 with no calliper wheel issue.
Fixed that for you
Covkiller
Re: Will fitting the RS5 20" Rotor really affects handling/ride?
Post by Covkiller » Fri Apr 14, 2017 9:19 am
You saw me then
Post by Ian_C » Fri Apr 14, 2017 10:34 am
Haha, someone clearly went for a late night blast night in the small hours last night.... :biggrin3:
Users browsing this forum: Google Adsense [Bot] and 101 guests
